in the Mandriva Cooker SVN, I have seen this patch to RC6:
http://svn.mandriva.com/cgi-bin/viewvc.cgi/packages/cooker/grass/current/SOURCES/grass-6.4.0RC6-fix-link.patch?view=markup
fix linkage on python binding
1 --- swig/python/Makefile.link 2010-04-04 06:07:01.000000000 +0200
2 +++ swig/python/Makefile 2010-04-04 06:07:17.000000000 +0200
3 @@ -39,6 +39,7 @@
4 EXTRA_SWIG = ../include/python/my_typemaps.i ../include/python/common.i
5 SWIGFLAGS = $(ARCH_INC) -I../include/python -outdir .
6 EXTRA_CFLAGS = $(PYMOD_CFLAGS)
7 +EXTRA_LIBS = $(PYTHONLDFLAGS)
8 EXTRA_CLEAN_FILES := $(foreach M,$(MODULES),$(M)_wrap.o $(M)_wrap.c
$(M).pyc $(M).py _$(M).so)
9 CLEAN_SUBDIRS = NumPtr
Should we include it?
3 @@ -39,6 +39,7 @@
$(PYTHONLDFLAGS) is already be added by the _%.so rule in Python.make.
If there's a problem, maybe $(PYMOD_LDFLAGS) needs to be moved to the
right?
3 @@ -39,6 +39,7 @@
right?
And PYTHONLDFLAGS messes up the OS X build. Python.make conditionally adds it to PYMOD_LDFLAGS.
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
[Trillian] What are you supposed to do WITH a maniacally depressed robot?
[Marvin] You think you have problems? What are you supposed to do if you ARE a maniacally depressed robot? No, don't try and answer, I'm 50,000 times more intelligent than you and even I don't know the answer...
- HitchHiker's Guide to the Galaxy
