[GRASS-dev] Fixed: GRASS-GIS/grass-ci#1635 (master - c575875)
Build #1635 was fixed.
15 minutes and 23 seconds
Václav Petráš
c575875 Changeset →
d.linegraph: let user provide Y tics [news]
Generated tics disabled when user provided.
No unlabeled tics generated. Printed as provided by
the user (strings, not numbers). Tics out of range simply
ignored.
This is also a workaround for tics with decimal places
(automatic tics work only with integers).
git-svn-id: https://svn.osgeo.org/grass/grass/trunk@69677 15284696-431f-4ddb-bdfa-cd5b030d7da7
Want to know about upcoming build environment updates?
Would you like to stay up-to-date with the upcoming Travis CI build environment updates? We set up a mailing list for you! Sign up here.
Documentation about Travis CI
Need help? Mail support!
Choose who receives these build notification emails in your configuration file.
Would you like to test your private code?
Travis CI for Private Projects could be your new best friend!
