[GRASS-dev] Fixed: GRASS-GIS/grass-ci#1853 (master - ccd9b3d)
Build #1853 was fixed.
1 hour, 21 minutes, and 48 seconds
Václav Petráš
ccd9b3d Changeset →
rst: add raster and gmath to libraries
Also reorder libraries to more common order.
Add dependencies synced to libs.
Leave math in libs as in other modules
although it likely should be in extra or just get it from link command.
This is meant to fix compilation on Mac where some of the libs are
in EXTRA_LIBS which is reasigned.
git-svn-id: https://svn.osgeo.org/grass/grass/trunk@70334 15284696-431f-4ddb-bdfa-cd5b030d7da7
Want to know about upcoming build environment updates?
Would you like to stay up-to-date with the upcoming Travis CI build environment updates? We set up a mailing list for you! Sign up here.
Documentation about Travis CI
Need help? Mail support!
Choose who receives these build notification emails in your configuration file.
Would you like to test your private code?
Travis CI for Private Projects could be your new best friend!
