[GRASS-dev] Fixed: GRASS-GIS/grass-ci#2402 (master - afea627)
Build #2402 was fixed.
7 minutes and 15 seconds
Václav Petráš
afea627 Changeset →
travis: we are currently not using the dataset, so no download needed
git-svn-id: https://svn.osgeo.org/grass/grass/trunk@71869 15284696-431f-4ddb-bdfa-cd5b030d7da7
System message:
We are updating to Xcode 8.3! By default, macOS builds will now use Xcode 8.3 unless otherwise specified. Read more here.
Want to know about upcoming build environment updates?
Would you like to stay up-to-date with the upcoming Travis CI build environment updates? We set up a mailing list for you! Sign up here.
Documentation about Travis CI
Need help? Mail support!
Choose who receives these build notification emails in your configuration file.
Would you like to test your private code?
Travis CI for Private Projects could be your new best friend!
