[GRASS-dev] floating values stored in tables with max 6 decimal points
Try the following. I think it is a bug. There seems no reason why
vectors couldn't have floating point attributes with more than 6
decimal points:
$ r.mapcalc 'map=0.0000001'
$ r.to.vect input=map output=mapv feature=point
$ d.vect mapv
$ d.what.vect
You get zeros, while it should return 0.0000001. If I examine the dbf
in oocalc, there are zeros indeed!
Moreover, even when I create a datable some other way (eg. a dbf in
oocalc) and it has numbers with 7 decimal places stored, d.what.vect,
v.to.db, v.db.select round the output down, so that eg. 0.0000001
becomes 0.
Looks like a silent data corruption.
Maciek
decimal points:
$ d.vect mapv
$ d.what.vect
becomes 0.
this is 6.3-cvs, not 6.0.2, correct?
In dbmi_base/valuefmt.c, 6.3-cvs uses:
db_convert_value_to_string()
        case DB_C_TYPE_DOUBLE:
            sprintf (buf, "%lf",db_get_value_double(value));
            G_trim_decimal(buf);
            break;
this prints to many many decimal places (~30?) then trims off trailing
zeros any time a value is read from a DOUBLE column in the DB table.
GRASS 6.0.2 just printed six places after the decimal point.
(but still "%lf" ? I feel I'm still leaving something out.......?)
If this is 6.3, maybe there is somewhere else in the code which needs
"%lf" + G_trim_decimal()? [db_convert_Cstring_to_value() ?]
Hamish
Yes, 6.3 CVS 2006-10-24 (yesterday).
