[GRASS-dev] fns with the same name -> segfault
v.out.svg --interface-description
ends with segfault.
[gcc (GCC) 4.2.3 (Debian 4.2.3-2)]
After some investigation I found out that the reason is function
print_escaped_for_xml() in vector/v.out.svg/main.c. Function with the
same name is also included in lib/gis/parser.c.
I am not sure about right solution here, I guess changing
print_escaped_for_xml() in parser.c to be static function...(?)
Thanks in advance, Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa *
ends with segfault.
Yes; fixed in SVN. As well as changing parser.c, I have also changed
all of the functions in vector/v.out.svg/main.c except main().
More generally, functions which aren't meant to be used outside of the
source file where they are defined should be declared "static" to
document this fact.
For modules consisting of a single source file, all functions except
main() should be declared "static".
