William Kyngesburye wrote:
>> Note that font names on OSX aren't required to follow any file
>> extension conventions. First the HFS+ file type/creator is used to
>> determine if a file is a font, then the file extension if the type/
>> creator are empty. I think it's that order.
>> So scanning automatically for fonts to create the freetypecap may
>> miss many fonts, unless it knew how to check OSX type/creator info
>> for a file.
>> ie the MS fonts that come with the system have no extension. Also,
>> many TT fonts in OSX have been repackaged in the .dfont (a flattened
>> resource-fork file).
> In which case, users will need to construct the freetypecap file
> manually.
If you do that, there is not much point to the automatic scan - most
of the useful TT fonts that are included with OSX are either dfonts
or have no extension. Most, if not all, of the included .ttf TT
fonts are miscellaneous language fonts.
But, then there is another problem (and in general TT font usage) -
d.font.freetype doesn't handle multiple faces in a file. Many dfonts
and resource fonts (the ones with no extension) have multiple faces
in a single file (ie regular, italic, bold..). Without specifying
the face index or name, freetype defaults to the first face in a font
file. (I thought I made a feature request for this, but I don't see
it in either tracker) There is no guarantee that plain/regular will
be the first face in a font file, so you may get italic or bold or
other unexpected style.
Regarding both cases (mkftcap and R_font()), fixes are welcome. They
will need to come from someone who can devise (and test) a solution,
though (i.e. someone with a Mac).
A few more comments:
- Add /System/Library/Fonts to the search paths (assuming some way to
handle other file extensions, or lack of, is worked out, as well as
multiple faces in a file).
$HOME/Library/Fonts would be another good default dir to search. And
to do these in the proper OSX order of precedence would be: $HOME/
Library/Fonts /Library/Fonts /System/Library/Fonts. $HOME can have
spaces if it's on a network driver, so that path at least should be
quoted.
These are easy enough to do (adding the directory, not the other
parts). Even if it doesn't do anything yet because there are no .ttf
files there, it's harmless.
- Maybe Michael's proposed font path env var could be used here? For
additional user font paths to search automatically.
I can add "$@" to the list used by mkftcap, so other directories can
be passed as arguments. Environment variables are problematic when
directories contain spaces, but command-line arguments can be quoted.
- since this is now in /tools and installed in etc/, that implies
that mkftcap will get run automatically somehow? From GUI? Or some
future script module? On startup?
At present, it gets run at build time; thereafter, it has to be run
manually. It could be run from a post-install script used by the
packaging system (.deb, .rpm, etc).
It isn't intended to be run automatically during normal use.
Then it will destroy a user's
manually created freetypecap, so it should be as thorough as
possible. Or add some sort of divider in the freetypecap between
user entries and auto-generated entries, and mkftcap would not
overwrite user edits.
Reasonable enough. Also, I'm considering making it write to stdout
rather than $GISBASE/etc/freetypecap. That allows it to write to some
other file, which can then be referenced by $GRASS_FT_CAP.
Also for preserving user additions, you could use e.g.:
mkftcap > freetypecap.new
cat freetypecap.new $GISBASE/etc/freetypecap | sort | uniq > freetypecap.tmp
mv -f freetypecap.tmp $GISBASE/etc/freetypecap
This won't preserve deletion or re-ordering, but it's trivial to
implement. If the user has a local $GRASS_FT_CAP, an alternative is:
diff -u $GISBASE/etc/freetypecap freetypecap.new | patch $GRASS_FT_CAP
rm -f freetypecap.new
- regenerating the freetypecap at runtime in the GRASS application
folder is not a good thing on OSX (see my previous discussions about
OSX apps and user preference/config/addon files). There should be
some way to have GRASS look for alternative external freetypecap
files, for both generating the freetypecap file, and reading it to
set the font.
The code which reads the file already uses $GRASS_FT_CAP if that is
set.
