In a grassy script, how can I force verbosity, i.e. --v whenever a flag
-l is instructed? Which will lead to
env['GRASS_VERBOSE'] = '3'
i.some.module input=some_input -l
should be identical to
i.some.module input=some_input -l --v
The following is, of course, not working:
#%rules
#% requires_all: -l,--v
#%end
Regards, Nikos
* Moritz Lennert <moritz.lennert@ulb.ac.be> [2017-10-09 10:59:25 +0200]:
#%rules
#%end
I don't think the -- flags are covered by the rules, so I think you have to do this in the code, i.e. something like this:
if flags['l']:
Merci Moritz,
I tested already (before asking)
env = os.environ.copy()
if list_only:
but it does not work.
Aren't there other ways?
Thank you again, N
* Nikos Alexandris <nik@nikosalexandris.net> [2017-10-09 12:18:29 +0200]:
#%rules
#%end
if flags['l']:
Merci Moritz,
if list_only:
Thank you again, N
I guess simply
GRASS_VERBOSE=3
export GRASS_VERBOSE
It works!
See https://grasswiki.osgeo.org/wiki/Scripting
N
#%rules
#%end
if flags['l']:
Merci Moritz,
if list_only:
Yes, sorry, I just copied your line without thinking.
Thank you again, N
I guess simply
GRASS_VERBOSE=3
It works!
Yes, but that's in a shell, not in Python, or ?
In Python, something like this should work IIRC:
import os
os.environ['GRASS_VERBOSE'] = '3'
Moritz
* Moritz Lennert <mlennert@club.worldonline.be> [2017-10-09 13:05:45 +0200]:
#%rules
#%end
if flags['l']:
Merci Moritz,
if list_only:
Thank you again, N
I guess simply
GRASS_VERBOSE=3
It works!
import os
But of course it works! Don't know why I got stuck with env instead
os.environ.
Thanks, Nikos
Nikos:
if list_only:
Moritz:
import os
os.environ.
For the records, it's somewhat about the logic of the script I am
building. Yet also that, copy(), as used in the first example,
creates a shallow copy. Deep copy works, i.e.
`env=copy.deepcopy(os.environ)` or simply `env=os.environ`
Nikos
It shouldn’t, you copied the environment, you didn’t change the environment used. You would have to take the copied env and pass it to run_command, then it would work. Or of course, modify the actual environment, not the copied one. Hope this clarifies it a bit.
Anna
env[‘GRASS_VERBOSE’] = ‘3’
#%rules
#% requires_all: -l,–v
#%end
I don’t think the – flags are covered by the rules, so I think you have to do this in the code, i.e. something like this:
if flags[‘l’]:
Merci Moritz,
if list_only:
Aren’t there other ways?
Thank you again, N
grass-dev mailing list
grass-dev@lists.osgeo.org
https://lists.osgeo.org/mailman/listinfo/grass-dev
