I would like to use a different version of Python from the default install in the PC,
is there a way to force it in the configure script?
thx
Yann
thx
Yann
On Fri, Feb 20, 2015 at 1:47 PM, Yann Chemin <ychemin@gmail.com> wrote:
Not (yet) AFAIK. But you can modify it after the "configure" step here:
include/Make/Platform.make:PYTHON = python
There is at time the hardcoded name:
include/Make/Platform.make.in:PYTHON = python
Other option: use "alias":
[neteler@pgis_north ]$ python --version
Python 2.7.8
[neteler@pgis_north ]$ alias python=python3.4
Python 3.4.1
Then run "configure" etc. Of course the alias must then persist later,
so put it into $HOME/.bashrc or similar.
is there a way to force it in the configure script?Not (yet) AFAIK. But you can modify it after the "configure" step here:
include/Make/Platform.make.in:PYTHON = pythonOther option: use "alias":
Python 2.7.8[neteler@pgis_north ]$ alias python=python3.4
Python 3.4.1Then run "configure" etc. Of course the alias must then persist later,
Doesn't 'export GRASS_PYTHON=YourChoiceOfPython' simply do the trick at runtime ?
Moritz
Python 3.4.1
I thought alias works just for command line but the processes, e.g.
scripts, does not get them.
Python 3.4.1I thought alias works just for command line but the processes, e.g. scripts,
does not get them.
Combined attempt:
[neteler@pgis_north ]$ export GRASS_PYTHON=python3.4
[neteler@pgis_north ]$ grass71
Cleaning up temporary files...
Starting GRASS GIS...
GRASS 7.1.svn (nc_spm_08_grass7):~ > echo $GRASS_PYTHON
python3.4
GRASS 7.1.svn (nc_spm_08_grass7):~ > v.rast.stats
File "/home/neteler/software/grass71/dist.x86_64-unknown-linux-gnu/gui/wxpython/gui_core/forms.py",
line 2375
raise gcmd.GException, _("Unable to parse command '%s'") % ' '.join(cmd)
SyntaxError: invalid syntax
Did you refer to this problem, Vaclav?
>> Python 3.4.1
scripts,
> does not get them.I refer to this:
$ echo "echo Hello." > test.sh
$ chmod u+x test.sh
$ alias echo='echo "MESSAGE: "'
$ echo Hello
MESSAGE: Hello
$ ./test.sh
Hello.
Combined attempt:
...GRASS 7.1.svn (nc_spm_08_grass7):~ > echo $GRASS_PYTHON
python3.4GRASS 7.1.svn (nc_spm_08_grass7):~ > v.rast.stats
File
line 2375
'.join(cmd)
SyntaxError: invalid syntaxDid you refer to this problem, Vaclav?
No, but I guess that especially GUI is not Python 3 ready as well as
wxPython.
Vaclav
No.
You can control the interpreter used for building by overriding the
PYTHON make variable, e.g.
make PYTHON=/path/to/python ...
For controlling the interpreter used at run time:
On Windows, Python scripts are invoked via %GRASS_PYTHON%, so changing
that environment variable will change the interpreter.
On Unix, GRASS_PYTHON is only used for components which use wxPython,
e.g. wxGUI or the parameter dialogs which are displayed when modules
are run without arguments.
Scripts rely upon the "#!/usr/bin/env python" line. You can control
the interpreter used by scripts by creating a directory containing a
symlink named "python" which refers to your preferred version of the
interpreter, and placing that directory at the front of $PATH.
