[GRASS-dev] Forestfrag WARNING: ZSTD compression error -14: Unsupported frame parameter
Hi Václav / devs
I am running r.forestfrag in Windows 10, grass 7.6.2 Computation with a moving window size of 21 (but at another computer same happens at size 9) gives met the following error:
C:\Users\brp\AppData\Roaming\GRASS7\addons/scripts/r.forestfrag.py input=groenreclass@landschap output=AAtest7 size=21
Step 1: Computing Pf values…
Step 2: Computing Pff values…
ERROR: Error uncompressing raster data for row 328 of <tmpA04_398bad3c_32a8_4220_8566_374c8c9f16a8>
WARNING: No data base element files found
File “C:\Users\brp\AppData\Roaming\GRASS7\addons/scripts/r.forestfrag.py”, line 420, in sys.exit(main(*gs.parser()))
File “C:\Users\brp\AppData\Roaming\GRASS7\addons/scripts/r.forestfrag.py”, line 290, in main ipl=ipl, tmpl4=expr1, tmpl5=expr2, pff=pff)
File “C:\OSGEO4~1\apps\grass\grass76\etc\python\grass\script\raster.py”, line 111, in mapcalc " with expression: %s") % e)
File “C:\OSGEO4~1\apps\grass\grass76\etc\python\grass\script\core.py”, line 667, in fatal error(msg)
File “C:\OSGEO4~1\apps\grass\grass76\etc\python\grass\script\core.py”, line 651, in error message(msg, flag=‘e’)
File “C:\OSGEO4~1\apps\grass\grass76\etc\python\grass\script\core.py”, line 584, in message run_command(“g.message”, flags=flag, message=msg, errors=‘ignore’)
File “C:\OSGEO4~1\apps\grass\grass76\etc\python\grass\script\core.py”, line 415, in run_command ps = start_command(*args, **kwargs)
File “C:\OSGEO4~1\apps\grass\grass76\etc\python\grass\script\core.py”, line 382, in start_command
return Popen(args, **popts)
File “C:\OSGEO4~1\apps\grass\grass76\etc\python\grass\script\core.py”, line 76, in init subprocess.Popen.init(self, args, **kwargs)
File “C:\OSGEO4~1\apps\Python27\lib\subprocess.py”, line 390, in init errread, errwrite)
File “C:\OSGEO4~1\apps\Python27\lib\subprocess.py”, line 640, in _execute_child startupinfo)
WindowsError: [Error 206] De bestandsnaam of -extensie is te lang
Any idea what may be the problem here?
Greetings,
Paulo
On Mon, May 27, 2019 at 3:25 PM Paulo van Breugel <p.vanbreugel@gmail.com> wrote:
Hi Václav / devs
Some computations happened, but then something went wrong.
Something wrong with the libraries or the files (perhaps not enough space on disk?).
Probably, g.remove trying to clean something as the the script is exiting. Likely harmless.
Here, it is g.message failing, so at this point nothing works.
Too many open files? Or maybe just the error message happens to be too long.
Try smaller region, smaller window. Look into task manager. …
Best,
Vaclav
Greetings,
Paulo
Hi Václav / devs
It goes wrong when with the moving window computation using r.mapcalc. But when (e.g., with what moving window size) differs depending on the computer and the size of the raster.
I guess something with the files, as it works with smaller moving windows and it works in Linux.
Ah, ok
I did try a smaller region, this does seem to make a difference. I will try if I can do this more systematically.
Best,
Vaclav
Greetings,
Paulo
On Tue, May 28, 2019 at 6:26 PM Paulo van Breugel <p.vanbreugel@gmail.com> wrote:
Hi Václav / devs
This is probably a read error: data are not correctly read from disk. But this should be reported as a read error.
A ZSTD compression error has been reported previously when a raster map was compressed with ZSTD 1.3.x and on another system decompressed with ZSTD 1.3.y. Not sure if this applies here as well.
Markus M
Ah, ok
Best,
Vaclav
Greetings,
Paulo
grass-dev mailing list
grass-dev@lists.osgeo.org
https://lists.osgeo.org/mailman/listinfo/grass-dev
