A change in OSX Leopard (10.5) that may affect GRASS, though I haven't seen any problems yet. From a release note for the developer tools:
CoreFoundation and fork()
Due to the behavior of fork(), CoreFoundation cannot be used on the child-side of fork(). If you fork(), you must follow that with an exec*() call of some sort, and you should not use CoreFoundation APIs within the child, before the exec*(). The applies to all higher-level APIs which use CoreFoundation, and since you cannot know what those higher-level APIs are doing, and whether they are using CoreFoundation APIs, you should not use any higher-level APIs either. This includes use of the daemon() function.
Additionally, per POSIX, only async-cancel-safe functions are safe to use on the child side of fork(), so even use of lower-level libSystem/BSD/UNIX APIs should be kept to a minimum, and ideally to only async-cancel-safe functions.
This has always been true, and there have been notes made of this on various Cocoa developer mailling lists in the past. But CoreFoundation is taking some stronger measures now to "enforce" this limitation, so we thought it would be worthwhile to add a release note to call this out as well. A message is written to stderr when something uses API which is definitely known not to be safe in CoreFoundation after fork(). If file descriptor 2 has been closed, however, you will get no message or notice, which is too bad. We tried to make processes terminate in a very recognizable way, and did for a while and that was very handy, but backwards binary compatibility prevented us from doing so.
If a process forks and a corefoundation unsafe function is used, you get a warning in the console:
The process has forked and you cannot use this CoreFoundation functionality
safely. You MUST exec().
Break on
__THE_PROCESS_HAS_FORKED_AND_YOU_CANNOT_USE_THIS_COREFOUNDATION_FUNCTIONALITY___YOU_MUST_EXEC__()
to debug.
This can quickly clog the console and log files. While it doesn't seem to affect GRASS, an improperly-built TclTk can cause trouble. I ran into this when testing NVIZ for the pixmap/pbuffer export bug.
I've updated the OSX Readme TclTk build example to include an extra configure option:
--disable-corefoundation
Since the example is for an X11 TclTk build, CoreFoundation isn't really necessary, so this is OK.
And, though the warning log problem is Leopard-only, the forking is still a potential issue with earlier OSX versions, so this option should be used for all OSX versions.
For a TclTk Aqua build (for those that are willing to brave other problems), CoreFoundation is needed. It is currently only partially fixed in Tcl (8.4 and 8.5) - for 64bit only, though it also happens in 32bit mode.
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"I ache, therefore I am. Or in my case - I am, therefore I ache."
- Marvin
