Looking into some v6 to v7 coding translation, how would you test for
readability of raster cell header in v7
<from grass-addons: i.landsat.toar>
mapset = G_find_cell2(band_in, "");
if (mapset == NULL) {
G_warning(_("Raster map <%s> not found"), band_in);
continue;
if ((infd = G_open_cell_old(band_in, mapset)) < 0)
G_fatal_error(_("Unable to open raster map <%s>"), band_in);
if (G_get_cellhd(band_in, mapset, &cellhd) < 0)
G_fatal_error(_("Unable to read header of raster map <%s>"), band_in);
if (G_set_window(&cellhd) < 0)
G_fatal_error(_("Cannot reset current region"));
The Last 4 lines I am trying to see if Rast_get_cellhd should be used...
if (Rast_get_cellhd(band_in, "", &cellhd) < 0)
<%s>"), band_in);
These 4 lines above are returning errors because the two functions
Rast_get_cellhd and G_set_window both return void, and they are tested
for a return value.
How would you rewrite that initial code within version 7?
Thank you,
Yann
Yann Chemin
Senior Spatial Hydrologist
www.csu.edu.au/research/icwater
M +61-4-3740 7019
continue;
for a return value.
Remove the test. If a 6.x function returned a status and the 7.x
version doesn't return anything, it means that the 7.x version calls
G_fatal_error() itself.
I made this change for almost every lib/raster function where the only
consequence of an error return was to call G_fatal_error() (assuming
that the code bothered to check the return value in the first place).
Also, note that Rast_open_* will only ever return a valid descriptor.
If something goes wrong, it results in a fatal error, so there's no
point in explicitly checking for "fd < 0".
Functions which read metadata files which may or may not exist
(categories, colour tables, etc) still return status codes.
On 13 October 2010 16:27, Glynn Clements <glynn@gclements.plus.com> wrote:
Yann Chemin wrote:
some confusion you may clarify.
mapset = G\_find\_cell2\(band\_in, ""\);
if \(mapset == NULL\) \{
G\_warning\(\_\("Raster map <%s> not found"\), band\_in\);
continue;
if \(\(infd = G\_open\_cell\_old\(band\_in, mapset\)\) < 0\)
G\_fatal\_error\(\_\("Unable to open raster map <%s>"\), band\_in\);
if \(G\_get\_cellhd\(band\_in, mapset, &cellhd\) < 0\)
G\_fatal\_error\(\_\("Unable to read header of raster map <%s>"\), band\_in\);
if \(G\_set\_window\(&cellhd\) < 0\)
G\_fatal\_error\(\_\("Cannot reset current region"\)\);
if \(Rast\_get\_cellhd\(band\_in, "", &cellhd\) < 0\)
for a return value.
Yann Chemin
M +61-4-3740 7019
