[GRASS-dev] frustration compiling GRASS on Mac
A couple weeks ago, I was able to compile GRASS master with some effort and tweaking.
Now it won’t compile, and neither will RB 7.8.2
I get a totally new error with libwebp.7.dylib listed below. I am using the same setups I used a couple weeks ago. Any advice???
1 warning generated.
gcc -I/Applications/GRASS-7.8.app/Contents/Resources/include -g -O2 -arch x86_64 -isysroot /Developer/SDKs/MacOSX10.14.sdk -I/Applications/GRASS-7.8.app/Contents/Resources/include -I/Users/cmbarton/grass_source/master/grass/dist.x86_64-apple-darwin18.7.0/include -I/Users/cmbarton/grass_source/master/grass/dist.x86_64-apple-darwin18.7.0/include -I/Applications/GRASS-7.8.app/Contents/Resources/include -I/Applications/GRASS-7.8.app/Contents/Resources/include -DPACKAGE="“grassmods”" -I/Users/cmbarton/grass_source/master/grass/dist.x86_64-apple-darwin18.7.0/include -I/Users/cmbarton/grass_source/master/grass/dist.x86_64-apple-darwin18.7.0/include -DRELDIR="lib/raster3d/test" -o OBJ.x86_64-apple-darwin18.7.0/test_tools.o -c test_tools.c
: && gcc -L/Users/cmbarton/grass_source/master/grass/dist.x86_64-apple-darwin18.7.0/lib -L/Users/cmbarton/grass_source/master/grass/dist.x86_64-apple-darwin18.7.0/lib -arch x86_64 -isysroot /Developer/SDKs/MacOSX10.14.sdk -L/Applications/GRASS-7.8.app/Contents/Resources/lib -Xlinker -rpath -Xlinker /Applications/GRASS-7.8.app/Contents/Resources/lib -Xlinker -rpath -Xlinker /Users/cmbarton/grass_source/master/grass/dist.x86_64-apple-darwin18.7.0/lib -o /Users/cmbarton/grass_source/master/grass/dist.x86_64-apple-darwin18.7.0/bin/test.raster3d.lib OBJ.x86_64-apple-darwin18.7.0/test_coordinate_transform.o OBJ.x86_64-apple-darwin18.7.0/test_main.o OBJ.x86_64-apple-darwin18.7.0/test_put_get_value.o OBJ.x86_64-apple-darwin18.7.0/test_put_get_value_large_file.o OBJ.x86_64-apple-darwin18.7.0/test_tools.o -lgrass_gis.7.8 -lgrass_g3d.7.8 -lgrass_raster.7.8
install_name_tool -change libgdal.20.dylib @rpath/libgdal.20.dylib /Users/cmbarton/grass_source/master/grass/dist.x86_64-apple-darwin18.7.0/bin/test.raster3d.lib
if [ “/Users/cmbarton/grass_source/master/grass/dist.x86_64-apple-darwin18.7.0/bin/test.raster3d.lib” != “” ] ; then GISRC=/Users/cmbarton/grass_source/master/grass/dist.x86_64-apple-darwin18.7.0/demolocation/.grassrc78 GISBASE=/Users/cmbarton/grass_source/master/grass/dist.x86_64-apple-darwin18.7.0 PATH=“/Users/cmbarton/grass_source/master/grass/dist.x86_64-apple-darwin18.7.0/bin:/Users/cmbarton/grass_source/master/grass/dist.x86_64-apple-darwin18.7.0/bin:/Users/cmbarton/grass_source/master/grass/dist.x86_64-apple-darwin18.7.0/scripts:$PATH” LD_RUN_PATH=“/Users/cmbarton/grass_source/master/grass/dist.x86_64-apple-darwin18.7.0/bin:/Users/cmbarton/grass_source/master/grass/dist.x86_64-apple-darwin18.7.0/bin:/Users/cmbarton/grass_source/master/grass/dist.x86_64-apple-darwin18.7.0/scripts:/Users/cmbarton/grass_source/master/grass/dist.x86_64-apple-darwin18.7.0/lib:/Users/cmbarton/grass_source/master/grass/dist.x86_64-apple-darwin18.7.0/lib:/lib” PYTHONPATH=“/Users/cmbarton/grass_source/master/grass/dist.x86_64-apple-darwin18.7.0/etc/python:/Users/cmbarton/grass_source/master/grass/dist.x86_64-apple-darwin18.7.0/gui/wxpython:$PYTHONPATH” LC_ALL=C LANG=C LANGUAGE=C /Users/cmbarton/grass_source/master/grass/dist.x86_64-apple-darwin18.7.0/bin/test.raster3d.lib --html-description < /dev/null | grep -v ‘|’ > test.raster3d.lib.tmp.html ; fi
dyld: Library not loaded: @rpath/libwebp.7.dylib
Referenced from: /Applications/GRASS-7.8.app/Contents/Resources/lib/libtiff.5.dylib
Reason: Incompatible library version: libtiff.5.dylib requires version 9.0.0 or later, but libwebp.7.dylib provides version 8.0.0
make: *** [test.raster3d.lib.tmp.html] Error 1
rm test.raster3d.lib.tmp.html
C. Michael Barton
Head, Graduate Faculty in Complex Adaptive Systems Science
Arizona State University
voice: 480-965-6262 (SHESC), 480-965-8130/727-9746 (CSDC)
fax: 480-965-7671 (SHESC), 480-727-0709 (CSDC)
www: http://www.public.asu.edu/~cmbarton, https://complexity.asu.edu/csdc
