[GRASS-dev] FTBFS: segmentation fault in lib/vector/diglib/test.c
by chance I found this report in the Fedora 19 bugtracker:
https://bugzilla.redhat.com/show_bug.cgi?id=961838
-> Segmentation fault, looks like integer overflow.
Does anybody see the issue?
On Thu, May 23, 2013 at 10:53 PM, Markus Neteler <neteler@osgeo.org> wrote:
Fixed August 2011 in trunk r47992.
This affects only big endian systems.
Markus M
On Fri, May 24, 2013 at 8:24 AM, Markus Metz
Can I backport it then?
ok.
In theory yes, but only the changes introduced with r47992, not the
current version of lib/vector/diglib/portable.c in trunk.
The diglib test might then fail.
I was wrong, the portability test simulates a little endian and a big
endian system and can thus cause a segfault on any system.
Markus M
