[GRASS-dev] function to get mouse position
Hi Devs,
Is there a function that will return the coordinates of the mouse pointer, if it is inside a graphics window?
This on mouse-click.
Ideally the return value would be: button,x,y(,z)
Even more ideally, if mouse hovers inside a graphics window, and a keyboard key is press (say the letter 'k'), then the return value would be "k,x,y(,z)"
If any of you are old enough to have used Genamap, then I am looking to emulate its 'gloc' command.
TIA,
Zoltan
Zoltan Szecsei GPrGISc 0031
Geograph (Pty) Ltd.
GIS and Photogrammetric Services
Cape Town, South Africa.
Mobile: +27-83-6004028 (Signal, not WhatsApp)
www.geograph.co.za
Hi again,
OK, I was far to vague.......
What I am looking for is where in the digitising functions the mouse-clicks are collected to add/edit/etc the geometry elements.
I'm scratching through the 'C' progs and .py folders ..........but some guidance would shorten my quest.
Thanks and keep well,
Zoltan
On 2021/07/21 17:07, Zoltan wrote:
Hi Devs,
TIA,
Zoltan
Geograph (Pty) Ltd.
www.geograph.co.za
Apologies for the bandwidth taken - I should have though of this earlier:
grep -i -R --include "*.py" "mouse"
and
grep -i -R --include "*.c" "mouse"
Zoltan
On 2021/07/22 13:37, Zoltan wrote:
Hi again,
Zoltan
Hi Devs,
TIA,
Zoltan
Geograph (Pty) Ltd.
www.geograph.co.za
