[GRASS-dev] fuzzy clumping using r.clump in QGIS
Hi devs,
Not sure this should go to the QGIS mailing list instead. The grass gis r.clump function in QGIS does not include the threshold value as far as I can see. Do you know if this is intentionally, and if not, if it would be difficult to add?
With kind regards,
Paulo
Hi Paulo,
On Mon, May 3, 2021 at 12:36 AM Paulo van Breugel
<p.vanbreugel@gmail.com> wrote:
Hi devs,
This one is fine :slight_smile:
I suppose that there was no purpose to omit it.
Adding it might be easy, by editing
https://github.com/qgis/QGIS/blob/master/python/plugins/processing/algs/grass7/description/r.clump.txt
and proposing the change as a new pull request (happens upon saving).
Perhaps best is to first edit the local file (on my Linux box here):
/usr/share/qgis/python/plugins/processing/algs/grass7/description/r.clump.txt
and make tests, then submit the working change.
Best,
PS: A "threshold" you find e.g. in
https://github.com/qgis/QGIS/blob/master/python/plugins/processing/algs/grass7/description/r.watershed.txt
but the wording should follow that of r.clump.
