[GRASS-dev] G_check_input_output() and fully qualified output map name
I realized a strange behaviour of r.buffer, e.g.
$ r.buffer in=e out=e d=1
No error, input and output is the same...
$ r.buffer in=e out=e@user1 d=1
Illegal filename. Character <@> not allowed.
ERROR: <e@user> is an illegal file name
Why so restrictive? The current mapset is 'user1'.
I modified library function G_check_input_output() to handle also this case.
If mapset defined for output map is not the current one:
ERROR: Mapset defined for output map <e@user> is not the current mapset
Any objects to commit to CVS?
Martin
Martin Landa <landa.martin@gmail.com> * http://gama.fsv.cvut.cz/~landa *
(attachments)
legal_name.diff (4.4 KB)
r.buffer uses
   opt2 = G_define_standard_option(G_OPT_R_OUTPUT);
which defines
   Opt->gisprompt = "new,cell,raster";
the parser does check that the given name doesn't already exist.
Have you set the --overwrite enviro variable to be always on?
For the above example I get:
  ERROR: option <output>: <e> exists.
Presumably if you abuse --overwrite you get what you asked for.
output maps can only be written to the current mapset*. Allowing '@' is
redundant, requires code (ie additional habitat for bugs) to check that
what's after the '@' matches G_mapset(), and might put ideas in people's
heads that 'output=map@other_mapset' isn't banned.
[*] i.rectify is the exception, it writes to the target mapset which
was set with i.target
I agree that the error message could be better.
If it were me, I'd keep it simple with something like
if ( G_legal_filename(output) == -1 ) {
   if(strchr(output, '@'))
      G_fatal_error(_("Output map name should not include a mapset"));
Hamish
Hi Hamish,
2007/10/31, Hamish <hamish_nospam@yahoo.com>:
r.buffer uses
which defines
Hm, right I used GRASS_OVERWITE=1. But anyway why not use
G_check_input_output() in r.buffer and other modules with input/output
raster/vector maps? To avoid the same input and output?
Right, my question was based on GUI work. You can select from a dialog
as the output existing map from the current mapset (which is always
given as 'map@mapset'). Of course '@mapset' can be removed when
creating command string in GUI or to extend G_check_input_output() to
check also for fully qualified map name.
Martin
Hamish
