[GRASS-dev] g.copy bug?
Hello,
g.copy from mapsetA -> mapsetB does not work witht the most current cvs
version.
if I run g.copy rast=old@mapsetX,test1725heute
d.rast test1725heute
WARNING: can't read range file for [test1725heute in habitat_amount]
WARNING: color support for [test1725heute] in mapset [habitat_amount]
         missing
ERROR: Color file for [test1725heute] not available
r.support test1725heute
WARNING: Can't open header file for [test1725heute in habitat_amount]
Edit header for [test1725heute]? (y/n) [y]
Edit header for [test1725heute@habitat_amount]
WARNING: unable to open raster map [test1725heute in habitat_amount]
ERROR: Cannot open raster map [test1725heute]!
ERROR: Canceling from edit header.
r.info test1725heute
WARNING: category support for [test1725heute] in mapset [habitat_amount]
         missing
WARNING: can't get history information for [test1725heute] in mapset
         [habitat_amount]
ERROR: could not read range file
unfortunately my grass6 / 62 Debian versions are broken hence I cannot test it
using these releases.
can anybody report this bug as well?
Martin
BTW is there a way to move raster between mapsets?
Martin Wegmann wrote:
Hello,
version.
         missing
         missing
         [habitat_amount]
I can't reproduce this with a 2-day-version, which is after the recent
changes involving qualified names. I tried:
  $ g.mapsets mapset=glynn
  $ g.mapsets -p
  glynn
  $ g.copy elevation.dem@PERMANENT,foo
  Copy raster <elevation.dem@PERMANENT> to current mapset as <foo>
  $ ls /opt/grass-data/spearfish57/glynn/cell_misc/foo/
  null range
There may be other factors involved; can you create a minimal location
which demonstrates the issue?
Change to destination, g.copy, change to source, g.remove.
There isn't a faster way; you can't modify mapsets other than the
current one.
On Mon, Apr 23, 2007 at 05:31:26PM +0200, Martin Wegmann wrote:
Hello,
version.
         missing
Martin,
most likely a "make distclean" and full recompile will
cure the problem. Did you try this?
> Hello,
> version.
> missing
Martin,
my script does:
make clean
make distclean
cvs update -dP grass6
./configure --with-tcltk-includes=/usr/include/tcl8.4 --with-postgres-includes=/usr/include/postgresql --with-gdal=/usr/local/bin/gdal-config --enable-largefile
make
make install
I am recompiling it again and perhaps I'll redo it by-hand if it does not work
afterwards.
Martin
grass-dev mailing list
grass-dev@grass.itc.it
> Hello,
> version.
> missing
> missing
> [habitat_amount]
> test it using these releases.
  $ g.mapsets -p
  glynn
  null range
I did it with spearfish
g.copy rast=aspect@PERMANENT,testcopy
same error message with compilation from yesterday.
I finished cvs update, make clean, distclean, ./configure, make, make install
and now I get:
g.copy rast=aspect@PERMANENT,testcopy2
Copy raster <aspect@PERMANENT> to current mapset as <testcopy2>
Speicherzugriffsfehler
(-> Memory access error)
GRASS error or Linux problem? (Debian unstable)
r.info testcopy2
WARNING: Can't open header file for [testcopy2 in anna]
WARNING: category support for [testcopy2] in mapset [anna] missing
WARNING: can't get history information for [testcopy2] in mapset [anna]
WARNING: can't read range file for [testcopy2 in anna]
BTW I commented \visualization out due to errors in make - but that should not
affect it, should it?
current one.
well, stupid question - then I change destination as usual. thanks.
Martin
my script does:
make clean
make distclean
Being curious - doesn't "make distclean" alone suffice? Does'n it do
all that "make clean" does and more?
Maciek
> $ g.mapsets -p
> glynn
> null range
and now I get:
Works fine here.
  $ g.copy rast=aspect@PERMANENT,testcopy2
  $ r.info testcopy2
   | Layer: testcopy2 Date: Mon Nov 5 10:55:57 2001 |
   | Mapset: glynn Login of Creator: neteler |
   | DataBase: /opt/grass-data |
   | Title: aspect in degrees from east ( aspect ) |
   | timestamp: none |
Could you try it under gdb, e.g.:
  $ gdb g.copy
  > run rast=aspect@PERMANENT,testcopy2
  [segfault]
  > where
r.info testcopy2
No.
Maciej Sieczka wrote:
> my script does:
> make clean
> make distclean
Yes.
> > $ g.mapsets -p
> > glynn
> > null range
> install and now I get:
Works fine here.
  $ r.info testcopy2
   | | Mapset: glynn Login of Creator: neteler
   | | DataBase: /opt/grass-data
   | | Title: aspect in degrees from east ( aspect )
   | | timestamp: none
  $ gdb g.copy
  [segfault]
  > where
cvs update 1h ago
make distclean
rm -rf /usr/local/grass
./configure
make
make install
GRASS 6.3.cvs (spearfish60):~ > gdb g.copy
GNU gdb 6.6-debian
Copyright (C) 2006 Free Software Foundation, Inc.
GDB is free software, covered by the GNU General Public License, and you are
welcome to change it and/or distribute copies of it under certain conditions.
Type "show copying" to see the conditions.
There is absolutely no warranty for GDB. Type "show warranty" for details.
This GDB was configured as "i486-linux-gnu"...
Using host libthread_db library "/lib/i686/cmov/libthread_db.so.1".
(gdb) run rast=aspect@PERMANENT,testcopy7
Starting program: /usr/local/grass-6.3.cvs/bin/g.copy
Failed to read a valid object file image from memory.
[Thread debugging using libthread_db enabled]
[New Thread -1225282800 (LWP 13535)]
Copy raster <aspect@PERMANENT> to current mapset as <testcopy7>
Program received signal SIGSEGV, Segmentation fault.
[Switching to Thread -1225282800 (LWP 13535)]
do_copy (n=0, old=0x804e7f8 "aspect", mapset=0x804e840 "PERMANENT",
new=0x804e810 "testcopy7") at do_copy.c:40
40 for (i = 0; i < list[n].nelem; i++)
BTW how can I check that the running version is really the most recent one -
just in case I did a mistake and I am still starting an "old" grass63-cvs
version?
Martin
GNU gdb 6.6-debian
FWIW, I can't reproduce this.
(current GRASS 6.3 CVS built and running on Ubuntu Dapper, 32 bit, GCC
4.0.3, Pentium M, kernel 2.6.15-28-686)
Maciek
cvs update 1h ago
make distclean
./configure
make
make install
GNU gdb 6.6-debian
Odd. If n==0, the only way I can see of this causing a segfault is if
"list" is invalid, but "list" is used to initialise the option list
used by G_parser().
> cvs update 1h ago
> make distclean
> ./configure
> make
> make install
> GNU gdb 6.6-debian
> are welcome to change it and/or distribute copies of it under certain
> conditions. Type "show copying" to see the conditions.
> details. This GDB was configured as "i486-linux-gnu"...
used by G_parser().
I recompiled GRASS again - same error message.
just to be sure that I did not introduce a stupid mistake:
rm -rf
/usr/local/grass6-cvs-...
/usr/local/bin/grass6...
rm -rf
my_grass_cvs_folder
then:
export CVSROOT=:ext:martin@grasscvs:/grassrepository
export CVS_RSH=ssh
cvs -z3 co grass6
cd grass6
make
sudo make install
grass63
g.copy rast=old,new
if not GRASS related, can debian unstable cause this error?
Martin
> > cvs update 1h ago
> > make distclean
> > ./configure
> > make
> > make install
> > GNU gdb 6.6-debian
> > you are welcome to change it and/or distribute copies of it under
> > certain conditions. Type "show copying" to see the conditions.
> used by G_parser().
rm -rf
rm -rf
my_grass_cvs_folder
then:
export CVS_RSH=ssh
cvs -z3 co grass6
cd grass6
--with-gdal=/usr/local/bin/gdal-config --enable-largefile make
sudo make install
grass63
g.copy rast=old,new
BTW I get the same error using r.reclass (Speicherzugriffsfehler, memory
allocation error)
I compiled grass 6.2.1 and redid all analysis and this error prompt did not
appear hence it must be somehow related to grass6.3
Martin
Martin
