[GRASS-dev] g.copy rast=
hi list,
with the recent cvs version of grass63 g.copy for raster maps doesn't work any
more. i just get a meaningless 'memory access error' (speicherzugriffsfehler).
runinng configure, make, make install gives no error messages.
g.gisenv set="DEBUG=5"
g.copy rast=raster1,raster2
D3/5: Copy rast
Copy <raster1@hohenems_site> to current mapset as <raster2>
Speicherzugriffsfehler
r.info raster2
D2/5: G__home home = /home/rusch
WARNUNG: Kann Header-Datei [raster2 in hohenems_site] nicht öffnen
WARNUNG: Kategorie Unterstützung für [raster2] im Mapset [hohenems_site]
         missing
WARNUNG: Kann die History-Informationen der Karte [raster2] in Mapset
         [hohenems_site] nicht finden.
WARNUNG: Kann range Datei für [raster2 in hohenems_site] nicht lesen.
FEHLER: Kann die Wertespanne nicht lesen.
the problem appears on FC4,FC5 and FC6 aswell with following configuration:
FLAGS='-g -Wall' ./configure --with-x --enable-shared --with-proj
--with-gdal=/usr/local/bin/gdal-config --with-tcltk-includes=/usr/local/include
--with-postgres-includes=/usr/local/pgsql/include
--with-postgres-libs=/usr/local/pgsql/lib
--with-freetype-includes=/usr/include/freetype2 --with-freetype-libs=/usr/lib
--enable-largefile --with-odbc --with-motif --with-freetype=yes --with-cxx
--with-glw --with-nls --with-blas --with-lapack
--with-lapack-libs=/usr/local/lib --with-ffmpeg
--with-ffmpeg-includes=/usr/local/include/ffmpeg --with-sqlite
--with-proj-share=/usr/local/share/proj/ --enable-64bit --with-python
i don't know which libs/pkg are used by g.copy; but i tried different versions
of e.g. gdal ( gdal-1.3.2/gdal-1.4.0/gdal-svn; tcl/tk8.5a5/tcl/tk8.4.14) but it
seems to me that it's not dependent on a certain version of a package.
thanks alot!
martin
it is strange, on my machine g.copy works. What does gdb say?
Martin
2007/2/19, Martin Rutzinger <Martin.Rutzinger@uibk.ac.at>:
hi list,
D3/5: Copy rast
r.info raster2
         missing
thanks alot!
martin
grass-dev mailing list
grass-dev@grass.itc.it
Martin Landa <landa.martin@gmail.com> * http://gama.fsv.cvut.cz/~landa *
GRASS 6.3.cvs (utm):~ > gdb `which g.copy`
(gdb) run "rast=rott_one,test1"
Starting program: /usr/local/grass-6.3.cvs/bin/g.copy "rast=rott_one,test1"
[Thread debugging using libthread_db enabled]
[New Thread -1208944944 (LWP 13355)]
Copy <rott_one@hohenems_site> to current mapset as <test1>
Program received signal SIGSEGV, Segmentation fault.
[Switching to Thread -1208944944 (LWP 13355)]
do_copy (n=0, old=0xa02b838 "rott_one", mapset=0xa02b870 "hohenems_site",
new=0xa02b848 "test1") at do_copy.c:40
40 for (i = 0; i < list[n].nelem; i++)
(gdb)
Zitat von Martin Landa <landa.martin@gmail.com>:
Martin
> hi list,
any
> D3/5: Copy rast
> r.info raster2
> missing
versions
but it
> thanks alot!
> martin
hi,
cause i'm not familiar with grass c programming, i'm not sure what information
you need for error detection. so i followed the grass debugging manual on the
WIKI.
thanks,
martin
(gdb) run rast=rott_one,test1
Starting program: /usr/local/grass-6.3.cvs/bin/g.copy rast=rott_one,test1
[New Thread -1208621360 (LWP 13741)]
[Switching to Thread -1208621360 (LWP 13741)]
do_copy (n=0, old=0x8adc838 "rott_one", mapset=0x8adc870 "hohenems_site",
new=0x8adc848 "test1") at do_copy.c:40
(gdb) bt full
#0 do_copy (n=0, old=0x8adc838 "rott_one", mapset=0x8adc870 "hohenems_site",
        i = 0
        ret = <value optimized out>
        path =
"/data/grassdb/utm/hohenems_site/cell/rott_one\000-&#65533;M\\&#65533;dc\000\000&#65533;&#1079;\000\000\000R&#65533;\023Ndc\000\000&#65533;&#1079;\034&#65533;8&#65533;\024&#65533;&#65533;\031N\224&#1663;\224&#1663;,&#65533;=l\031N\224&#1663;\000\000\000\000\000\000\000\000}\004\bx&#1663;\235&#65533;027N$&#1663;\000\000\000\000\224&#1663;\001\000\000\000&#65533;wM&#65533;wM\004\033&#65533;234&#65533;&#65533;&#1663;-&#65533;M,&#65533;$wM\027\000\000\000\034&#65533;000\n&#288;"...
        path2 =
"/data/grassdb/utm/hohenems_site/cell/test1\000\000\000\000\005\000\000\000\b&#65533;&#65533;\003\000\000\000H&#65533;&#65533;&N&#65533;&NH&#65533;D&#65533;X&#65533;\002",
'\0' <repeats 11 times>,
"\200\b\006\000\000\000X&#65533;&#65533;031\033N\b8//\000&#65533;
&#65533;&#65533;\230\b\210)&#1655;\000\000\000\000\000\000\000\0000\b\000\000\000\000&#65533;&N\b0\b\025N&#65533;&#1663;rq\032N\b\210&#65533;&#65533;\b\000\000\000"...
        result = 0
#1 0x08049453 in main (argc=2, argv=0xbfd9fbd4) at copy.c:80
        n = <value optimized out>
        mapset = 0x8adc870 "hohenems_site"
        module = (struct GModule *) 0xcb3710
        parm = (struct Option **) 0x8adbb68
        p = <value optimized out>
        to = 0x8adc848 "test1"
        buf1 =
"&#65533;&#1663;\000\000\000\000\000\000\000\000\001\000\000\000F\b\000\000&#65533;033&#65533;&#65533;\212\004\bd\b\024N\203\004\b\001\000\000\000&#65533;wM\200wM<&#1663;X&#1663;P&#65533;M\203\004\b<&#1663;$wM\027\000\000\000&#65533;033&#65533;001\000\000\000\000\000\000\000\001\000\000\000\001\000\000\000\001\000\000\000\000\000\000\000\235A&\000H&#1663;\004\023NR&#65533;&#65533;\000&#65533;wM&#65533;&#65533;&#65533;000\200&#1663;&#65533;wMo\212\004\b\001\000\000\000\001\000\000\000\001\000\000\000.N=&#65533;000\000\000\000\000\200&#65533;000\220<9\000\025NX$\001\b&#65533;\001&#65533;&N"...
        location_path = 0x8adc858 "/data/grassdb/utm"
        result = 0
(gdb) l
35 G_warning ("Cannot copy <%s> to current mapset as <%s>",
36 G_fully_qualified_name(old, mapset), new );
37 result = 1;
38 }
39 } else {
41 {
42 G__make_mapset_element (list[n].element[i]);
43 G__file_name (path, list[n].element[i], old, mapset);
44 if (access (path, 0) != 0)
(gdb) frame 2
#0 0x00000000 in ?? ()
(gdb) l
45 {
46 G_remove (list[n].element[i], new);
47 if (G_verbose() == G_verbose_max())
48 G_message (_("%s: missing"), list[n].desc[i]);
49
50 continue;
51 }
52 G__file_name (path2, list[n].element[i], new, G_mapset());
53 if ( recursive_copy(path, path2) == 1 )
54 {
(gdb)
> Hi,
> Martin
> > hi list,
work
> any
> > D3/5: Copy rast
> > r.info raster2
> > missing
configuration:
--with-cxx
> versions
> but it
> > thanks alot!
> > martin
> > _______________________________________________
Martin,
I can confirm a segfault on using g.copy, with today's CVS on Ubuntu 6.06.
g.copy exits with a segfault, but the maps seems to get copied to the destination mapset as requested anyway. Only the command line run reaches a segfault, not the GUI version. Or maybe the error just isn't visible from the GUI.
Output from gdb:
$ gdb `which g.copy`
GNU gdb 6.4-debian
Copyright 2005 Free Software Foundation, Inc.
GDB is free software, covered by the GNU General Public License, and you are
welcome to change it and/or distribute copies of it under certain conditions.
Type "show copying" to see the conditions.
There is absolutely no warranty for GDB. Type "show warranty" for details.
This GDB was configured as "i486-linux-gnu"...Using host libthread_db library "/lib/tls/i686/cmov/libthread_db.so.1".
(gdb) run rast=Mispec_Apr2000.grd@UNB_Original_r4s,TEST_2
Starting program: /usr/local/grass-6.3.cvs/bin/g.copy rast=Mispec_Apr2000.grd@UNB_Original_r4s,TEST_2
[New Thread -1224742304 (LWP 7624)]
Copy <Mispec_Apr2000.grd@UNB_Original_r4s> to current mapset as <TEST_2>
[Switching to Thread -1224742304 (LWP 7624)]
0xb7eda963 in G_strcasecmp (x=0x804d800 "cell", y=0x532d87 <Address 0x532d87 out of bounds>) at strings.c:146
146 while (*x && *y)
(gdb)
Devs, any other info needed to diagnose this error?
~ Eric.
-----Original Message-----
To: Martin Landa
Cc: grass-dev
Sent: 2/19/2007 8:51 AM
Subject: Re: [GRASS-dev] g.copy rast=
"hohenems_site",
(gdb)
Martin
> hi list,
doesn't work
any
> D3/5: Copy rast
> r.info raster2
[hohenems_site]
> missing
Mapset
lesen.
configuration:
--with-cxx
--with-python
different
versions
but it
package.
> thanks alot!
> martin
did you use
make distclean
before compiling GRASS? Not sure, maybe it helps.
Martin
2007/2/19, Patton, Eric <epatton@nrcan.gc.ca>:
Martin,
Output from gdb:
GNU gdb 6.4-debian
(gdb)
~ Eric.
To: Martin Landa
Cc: grass-dev
"hohenems_site",
(gdb)
> Hi,
> Martin
> > hi list,
doesn't work
> any
> > D3/5: Copy rast
> > r.info raster2
[hohenems_site]
> > missing
Mapset
lesen.
configuration:
--with-cxx
--with-python
different
> versions
> but it
package.
> > thanks alot!
> > martin
Martin,
Yes, I ran make distclean before compiling.
~ Eric.
To: Patton, Eric
Cc: Martin Rutzinger; grass-dev
Sent: 2/19/2007 10:40 AM
did you use
make distclean
Martin
Martin,
6.06.
Output from gdb:
GNU gdb 6.4-debian
you are
conditions.
details.
<TEST_2>
(gdb)
~ Eric.
To: Martin Landa
Cc: grass-dev
"hohenems_site",
(gdb)
> Hi,
> Martin
> > hi list,
doesn't work
> any
> > D3/5: Copy rast
> > r.info raster2
[hohenems_site]
> > missing
Mapset
lesen.
configuration:
--with-cxx
--with-python
different
> versions
> but it
package.
> > thanks alot!
> > martin
On 19/02/07 16:45, Patton, Eric wrote:
Martin,
Just to let you know, that I cannot reproduce this with a freshly compiled CVS tree on Debian...
Moritz
i can not reproduce this error with the today's grass-CVS build on Debian etch. The grass test suite produces no errors:
GRASS 6.3.cvs > ./RunGRASSTestSuite.sh -g
Start testing general (g.*) modules
g.copy test: success success success success finished
g.findfile test: success finished
g.filename test: success finished
g.remove test: success success success success success success success success finished
g.rename test: success success success success success success success success finished
g.proj output test: success success success success success success success finished
g.tempfile test: success finished
g.gisenv test: success success finished
g.list test: success success success success success success success success success success success finished
g.region output test: success success success success success success success finished
g.version test: success success success finished
Finished testing general (g.*) modules
Soeren
Patton, Eric schrieb:
Martin,
Output from gdb:
GNU gdb 6.4-debian
(gdb)
~ Eric.
To: Martin Landa
Cc: grass-dev
"hohenems_site",
(gdb)
Martin
hi list,
doesn't work
any
D3/5: Copy rast
r.info raster2
[hohenems_site]
         missing
Mapset
lesen.
configuration:
--with-cxx
--with-python
different
versions
but it
package.
thanks alot!
martin
(gdb)
This looks like a problem with $GISBASE/etc/element_list.
unfortunately I this moning made fresh checkout and compilation. It
happens also here, on i686 Gentoo with gcc version 4.1.1.
It looks like segfault happens at general/manage/lib/do_copy.c line 53
"if ( recursive_copy(path, path2) == 1 )" where function
recursive_copy returns zero. I'm not so deep in C and that module, but
it segfaulted after recursive_copy calls "return 0", so - error must
be somewhere there.
Maris.
[Switching to Thread -1217730368 (LWP 6342)]
do_copy (n=0, old=0x8050398 "geology", mapset=0x8050420 "PERMANENT",
new=0x80503b0 "geol3") at do_copy.c:40
(gdb) bt
#0 do_copy (n=0, old=0x8050398 "geology", mapset=0x8050420
"PERMANENT", new=0x80503b0 "geol3") at do_copy.c:40
#1 0x080495d3 in main (argc=2, argv=0xbf9157a4) at copy.c:80
2007/2/19, Sören Gebbert <soerengebbert@gmx.de>:
Soeren
> Martin,
the GUI.
> Output from gdb:
> GNU gdb 6.4-debian
are
conditions.
details.
> (gdb)
> ~ Eric.
> From: grass-dev-bounces@grass.itc.it
> To: Martin Landa
> Cc: grass-dev
> "hohenems_site",
> (gdb)
>> Hi,
>> Martin
>>> hi list,
> doesn't work
>> any
>>> D3/5: Copy rast
>>> r.info raster2
> [hohenems_site]
>>> missing
> Mapset
> lesen.
> configuration:
> --with-cxx
> --with-python
> different
>> versions
>> but it
> package.
>>> thanks alot!
>>> martin
