I found strange construction in G__create_alt_search_path()
114 return 0; /* ??? */
115
116 get_list_of_mapsets();
see
http://trac.osgeo.org/grass/browser/grass/trunk/lib/gis/mapset_nme.c?rev=30718#L107
I guess that get_list_of_mapsets() should be called before return.
This function is used in few GRASS modules.
imagery/i.points/target.c: G__create_alt_search_path();
imagery/i.ortho.photo/photo.elev/main.c: G__create_alt_search_path();
imagery/i.ortho.photo/photo.2target/target.c: G__create_alt_search_path();
imagery/i.ortho.photo/photo.2image/target.c: G__create_alt_search_path();
imagery/i.vpoints/target.c: G__create_alt_search_path();
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa *
115
see
It doesn't actually need to be called at all. Setting nmapset to 0
will cause get_list_of_mapsets() to be called the next time that the
mapset list is queried.
2008/3/25, Glynn Clements <glynn@gclements.plus.com>:
> 115
> see
applied in trunk
http://trac.osgeo.org/grass/changeset/30726
Martin
