[GRASS-dev] g.extension.add available to install GRASS Addons SVN modules (GEM replacement)
I have written a simple script to replace GEM:
Example: install i.landsat.toar from GRASS Addons SVN:
  g.extension.add extension=i.landsat.toar
Or r.terracost (the lazy user may omit even extension=):
g.extension.add r.terracost
It will download, compile and install the requested module.
It can also be used to fetch a later update of course.
The script itself is yet in Addons [1]. It requires 6.4.0RC5 or 6.5.
It won't work with GRASS 7 since the "make install" support wasn't
yet implemented (see my other mail).
Feel free to improve/rewrite the module directly in SVN (ideally
rewrite it to Python).
[1] https://svn.osgeo.org/grass/grass-addons/general/g.extension.add/g.extension.add
2009/7/5 Markus Neteler <neteler@osgeo.org>:
done [2], untested. I would vote for moving this module to trunk and
integrate it into wxGUI. Probably it's less robust solution comparing
to GEM, anyway it's easier to maintain.
[2] https://svn.osgeo.org/grass/grass-addons/grass7/general/g.extension.add/g.extension.add
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa
2009/7/5 Martin Landa <landa.martin@gmail.com>:
typo in url...
Martin
done [2], untested.
wow cool!
yes & yes.
On Sun, July 5, 2009 17:30, Martin Landa wrote:
But it seems Linux-centric (e.g. "sudo"), so I'm not sure that this is a
good idea to integrate into the GUI, now that we are trying to be as
platform-independent as possible.
Moritz
2009/7/5 Moritz Lennert <mlennert@club.worldonline.be>:
Right, anyway I think that integration to GRASS 7 is first step to
rewrite the module (i.e. evolution) to be platform independent.
Martin
On Sun, Jul 5, 2009 at 7:17 PM, Moritz
Sure - but please ask precisely what's missing. Fails on Mac?
What's needed on Windows? More conditions can be added.
Certainly the python version is more suitable to be updated, my
shell script is a proof of concept.
then I would suggest to rename module to 'g.extension' for
adding/removing/updating selected extension. Make sense to you?
Martin
Moritz
The OSX app has a user modules dir that wouldn't need sudo. g.extension.add should support at least support an arbitrary install location. Maybe: prefix=
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"Oh, look, I seem to have fallen down a deep, dark hole. Now what does that remind me of? Ah, yes - life."
- Marvin
On Sun, Jul 5, 2009 at 7:55 PM, Martin Landa<landa.martin@gmail.com> wrote:
Sure!
BTW: I tried the python version but got two errors:
make MODULE_TOPDIR=/home/neteler/grass65
make: *** No rule to make target `g.extension.add', needed by
`/home/neteler/grass65/dist.x86_64-unknown-linux-gnu/scripts/g.extension.add'.
Stop.
(that happens because the script's name is g.extension.add.py)
I just added a link locally
ln -s g.extension.add.py g.extension.add
but obviously a change in
include/Make/Script.make
is desired.
g.extension.add i.landsat.toar
Converting: /home/neteler/grass64/dist.x86_64-unknown-linux-gnu/docs/html/i.landsat.toar.html
to /home/neteler/grass64/dist.x86_64-unknown-linux-gnu/man/man1/i.landsat.toar.1
make[2]: Leaving directory
`/home/neteler/grassdata/spearfish60/neteler/.tmp/localhost/30236.1/i.landsat.toar'
make[1]: Leaving directory
Installing 'i.landsat.toar'...
  File "/home/neteler/grass64/dist.x86_64-unknown-linux-gnu/scripts/g.extension.add",
line 161, in <module>
    sys.exit(main())
line 143, in main
    'install'])
  File "/home/neteler/grass64/dist.x86_64-unknown-linux-gnu/etc/python/grass/script/core.py",
line 54, in call
    return Popen(*args, **kwargs).wait()
line 48, in __init__
    startupinfo, creationflags)
  File "/usr/lib64/python2.6/subprocess.py", line 595, in __init__
    errread, errwrite)
  File "/usr/lib64/python2.6/subprocess.py", line 1106, in _execute_child
    raise child_exception
OSError: [Errno 2] No such file or directory
No idea what's wrong here.
2009/7/5 William Kyngesburye <woklist@kyngchaos.com>:
prefix=
done in r38264.
Martin
sys.exit(main())
line 143, in main
'install'])
line 54, in call
errread, errwrite)
Hopefully fixed in r38271.
Martin
> is a
Installing extensions via the GUI should install them for an
individual user, not system-wide.
System-wide installations should always be done via the OS' own
package management system: RPM, apt-get, portage, etc.
This isn't something GRASS can improve upon: it's one of those
situations where "different" is inherently "worse".
On Mon, Jul 6, 2009 at 12:11 AM, Glynn Clements<glynn@gclements.plus.com> wrote:
Fine with that but the GRASS 7 version currently defines:
g.extension -h
     prefix Prefix where to install extension
                default: $(HOME)/.grass/addons
I guess that this is an oversight and should be
                default: $(HOME)/.grass7/addons
Additionally: to fully make sense, shouldn't this directory be the default
value for the variable
GRASS_ADDON_PATH
in
lib/init/functions.sh
lib/init/grass.py
lib/init/init.bat
g.extension -h
GRASS_ADDON_PATH
GRASS_ADDON_PATH is to a bin folder, and can be multiple paths. The prefix for extension installation should be a single path to a standard bin/lib/etc structured folder.
in
lib/init/grass.py
lib/init/init.bat
"This is a question about the past, is it? ... How can I tell that the past isn't a fiction designed to account for the discrepancy between my immediate physical sensations and my state of mind?"
- The Ruler of the Universe
On Thu, Jul 30, 2009 at 11:07 PM, William
g.extension -h
I'll change to $(HOME)/.grass7/addons is there are no
objections.
GRASS_ADDON_PATH
structured folder.
As emerged earlier, it should be outside of the standard GRASS installation.
My point was: if GRASS_ADDON_PATH doesn't point to the g.extension
default, the users will install an extension and then won't find it since it
is not in the path.
in
lib/init/grass.py
lib/init/init.bat
2009/7/30 Markus Neteler <neteler@osgeo.org>:
structured folder.
is not in the path.
probably g.extension could check if given prefix is in
GRASS_ADDON_PATH and update it if needed?
Martin
