[GRASS-dev] g.extension.add available to install GRASS Addons SVN modules (GEM replacement)
Glynn wrote:
Installing extensions via the GUI should install them for
an individual user, not system-wide.
perhaps default to ~/.grass/addons/ ?
(together with rename of .grassrc7 in trunk (it's not a rc file).
call that ~/.grass/init ? or?)
Hamish
I was thinking about suggesting something like this, to mirror what I did for the OSX application build. To make it easily user-configurable, similar to other path settings, how about a GRASS env variable? This would make it easier to tailor it to OS conventions. I think this was briefly discussed once, but I don't remember what the suggestions were.
Currently for GRASS 7 I have the OSX user path as ~/Library/Application Support/GRASS/{version}/Modules. The version is the version used in the GRASS install dir name.
(For GRASS 6 I skipped the 'Application Support' subdir) The OSX startup just adds the .../bin dir to GRASS_ADDON_PATH.
Also, it should support multiple prefixes. Then there could be a user path, and a global path that an admin could add to without touching the GRASS base application ("bad thing" to do on OSX).
Note that (if it wasn't obvious) this dir should have the full complement of bin/lib/etc subdirs, since a module could have its own library and/or support files. And I added a GRASS_ADDON_ETC variable and g_find_etc to handle this, for modules that need to locate their support files.
On a side note, it would be nice to have built-in modules check with find_etc, so a user could add, say, color rule files that could be used in r.colors.
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"I ache, therefore I am. Or in my case - I am, therefore I ache."
- Marvin
2009/7/6 Hamish <hamish_b@yahoo.com>:
I like the idea of `.grass` directory. There is also .grasswx7 which
could be moved to `.grass/wx`.
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa
done in r38399.
BTW, is it possible to install separate module? Rule for 'install'
seems to be missing.
make MODULE_TOPDIR=path INST_DIR=path install
make: *** No rule to make target `install'. Stop.
Thanks in advance, Martin
On Jul 13, 2009, at 12:07 PM, Martin Landa wrote:
done in r38399.
Shouldn't the default be a configurable path? I'm thinking something that would point to the .grass folder, especially if we start using it for preferences and configuration info. Maybe GRASS_USER, or someone has a better suggestion?
This will let platform-specific startups set this and the user doesn't have to figure out where it is to specify it when installing an addon.
Theory of the Universe
There is a theory which states that if ever anyone discovers exactly what the universe is for and why it is here, it will instantly disappear and be replaced by something even more bizarrely inexplicable. There is another theory which states that this has already happened.
-Hitchhiker's Guide to the Galaxy 2nd season intro
