[GRASS-dev] g.extension does not find wx.animation in svn
i would like to install the great time series animation tool
"wx.animation" from Anna using g.extension. The module is listed in
the output of g.extension -l . Unfortunately it can not be installed:
GRASS 7.0.svn (Test):~> g.extension -s ext=wx.animation
Fetching <wx.animation> from GRASS-Addons SVN (be patient)...
svn: Die URL »http://svn.osgeo.org/grass/grass-addons/grass7/gui/wxpython/wx.animation«
does not exists
ERROR: GRASS Addons <wx.animation> not found
The svn directory is missing indeed. So my question is: Where is
wx.animation i really need it desperately.
Any suggestions are welcome.
Best regards
Soeren
2012/11/28 Sören Gebbert <soerengebbert@googlemail.com>:
the tool has been move recently by Anna to trunk.
File -> Animation tool
Martin
Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
Hi Martin,
thanks for your fast answer. The animation tool is now available in
the menu after i made a subversion update. Everything works fine now.
Best regards
Soeren
2012/11/28 Martin Landa <landa.martin@gmail.com>:
Martin
On Wed, Nov 28, 2012 at 2:28 PM, Sören Gebbert
<soerengebbert@googlemail.com> wrote:
Hi Martin,
Sorry Soeren, I should have told you. You can now access it also
through command line. Try
g.gui.animation --help
Anna
Best regards
Soeren
Martin
grass-dev mailing list
grass-dev@lists.osgeo.org
