I'll first ask here and then file a trak ticket if it seems appropriate.
Working in the current svn version of GRASS 7, I tried to install r.stream via g.extension. First, I tried from the command line in the terminal. Here is what happened.
GRASS 7.0.svn (Spain_wgs84z30):~ > g.extension -s extension=wx.stream
ERROR: install required. Please install 'install' first.
Then I tried from the g.extension menu item from the settings menu. Here is what I got in the console output window.
File "/Applications/GRASS/GRASS-7.0.app/Contents/MacOS/etc
/gui/wxpython/wxgui.py", line 1035, in OnInstallExtension
win = InstallExtensionWindow(self, size = (650, 550))
File "/Users/Shared/grass_dev/grass70_dev/dist.i386-apple-
darwin10.8.0/etc/gui/wxpython/gui_modules/ghelp.py", line
832, in __init__
self.statusbar = self.CreateStatusBar(0)
/python/wx/_windows.py", line 538, in CreateStatusBar
return _windows_.Frame_CreateStatusBar(*args, **kwargs)
wx._core
PyAssertionError
C++ assertion "m_nFields == (int)m_statusStrings.GetCount()"
failed at /BUILD/wxPython-
src-2.8.12.0/src/generic/statusbr.cpp(136) in
SetFieldsCount(): This really should never happen, can we do
away with m_nFields here?
Finally, I tried to launch g.extension from the terminal command line. The module launches. But when I try to install r.stream, I get the same "ERROR: install required. Please install 'install' first." message.
Are these the same error or several different errors.
Michael
____________________
C. Michael Barton
Arizona State University
voice: 480-965-6262 (SHESC), 480-727-9746 (CSDC)
fax: 480-965-7671 (SHESC), 480-727-0709 (CSDC)
www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.edu
