Hi All,
I’m having issues in using g.extension and before filing a bug report I should like to know whether am I not seeing anything obviously wrong from my side.
GRASS 6.4.3svn (nc_spm_08):~ > g.extension extension=r.stream.extract operation=add
Fetching <r.stream.extract> from GRASS-Addons SVN (be patient)…
A r.stream.extract/flag.h
A r.stream.extract/streams.c
A r.stream.extract/load.c
A r.stream.extract/del_streams.c
A r.stream.extract/local_proto.h
A r.stream.extract/thin.c
A r.stream.extract/rbtree.c
A r.stream.extract/main.c
A r.stream.extract/close.c
A r.stream.extract/description.html
A r.stream.extract/rbtree.h
A r.stream.extract/flag.c
A r.stream.extract/Makefile
A r.stream.extract/do_astar.c
U r.stream.extract
Checked out revision 54224.
Compiling <r.stream.extract>…
/usr/local/grass-6.4.3svn/include/Make/Grass.make:423: warning: overriding commands for target /home/madi/grassdata/nc_spm_08/testing/.tmp/amylee/3538.0/dist.x86_64/bin' /usr/local/grass-6.4.3svn/include/Make/Grass.make:414: warning: ignoring old commands for target
/home/madi/grassdata/nc_spm_08/testing/.tmp/amylee/3538.0/dist.x86_64/bin’
/usr/local/grass-6.4.3svn/include/Make/Module.make:25: warning: overriding commands for target install' /usr/local/grass-6.4.3svn/include/Make/Rules.make:99: warning: ignoring old commands for target
install’
mkdir -p /home/madi/grassdata/nc_spm_08/testing/.tmp/amylee/3538.0/dist.x86_64/bin
mkdir -p /home/madi/grassdata/nc_spm_08/testing/.tmp/amylee/3538.0/dist.x86_64/include/grass
mkdir -p /home/madi/grassdata/nc_spm_08/testing/.tmp/amylee/3538.0/dist.x86_64/etc
mkdir -p /home/madi/grassdata/nc_spm_08/testing/.tmp/amylee/3538.0/dist.x86_64/driver
mkdir -p /home/madi/grassdata/nc_spm_08/testing/.tmp/amylee/3538.0/dist.x86_64/driver/db
mkdir -p /home/madi/grassdata/nc_spm_08/testing/.tmp/amylee/3538.0/dist.x86_64/fonts
test -d OBJ.x86_64-unknown-linux-gnu || mkdir -p OBJ.x86_64-unknown-linux-gnu
gcc ‘-I/usr/local/grass-6.4.3svn/include’ ‘-I/home/madi/.grass6/addons/include’ ‘-I/home/madi/grassdata/nc_spm_08/testing/.tmp/amylee/3538.0/dist.x86_64/include’ -g -Wall -I/usr/local/include -I/usr/local/include -DPACKAGE="“grassmods”" ‘-I/usr/local/grass-6.4.3svn/include’ ‘-I/home/madi/.grass6/addons/include’ ‘-I/home/madi/grassdata/nc_spm_08/testing/.tmp/amylee/3538.0/dist.x86_64/include’ -o OBJ.x86_64-unknown-linux-gnu/close.o -c close.c
gcc ‘-I/usr/local/grass-6.4.3svn/include’ ‘-I/home/madi/.grass6/addons/include’ ‘-I/home/madi/grassdata/nc_spm_08/testing/.tmp/amylee/3538.0/dist.x86_64/include’ -g -Wall -I/usr/local/include -I/usr/local/include -DPACKAGE="“grassmods”" ‘-I/usr/local/grass-6.4.3svn/include’ ‘-I/home/madi/.grass6/addons/include’ ‘-I/home/madi/grassdata/nc_spm_08/testing/.tmp/amylee/3538.0/dist.x86_64/include’ -o OBJ.x86_64-unknown-linux-gnu/del_streams.o -c del_streams.c
gcc ‘-I/usr/local/grass-6.4.3svn/include’ ‘-I/home/madi/.grass6/addons/include’ ‘-I/home/madi/grassdata/nc_spm_08/testing/.tmp/amylee/3538.0/dist.x86_64/include’ -g -Wall -I/usr/local/include -I/usr/local/include -DPACKAGE="“grassmods”" ‘-I/usr/local/grass-6.4.3svn/include’ ‘-I/home/madi/.grass6/addons/include’ ‘-I/home/madi/grassdata/nc_spm_08/testing/.tmp/amylee/3538.0/dist.x86_64/include’ -o OBJ.x86_64-unknown-linux-gnu/do_astar.o -c do_astar.c
gcc ‘-I/usr/local/grass-6.4.3svn/include’ ‘-I/home/madi/.grass6/addons/include’ ‘-I/home/madi/grassdata/nc_spm_08/testing/.tmp/amylee/3538.0/dist.x86_64/include’ -g -Wall -I/usr/local/include -I/usr/local/include -DPACKAGE="“grassmods”" ‘-I/usr/local/grass-6.4.3svn/include’ ‘-I/home/madi/.grass6/addons/include’ ‘-I/home/madi/grassdata/nc_spm_08/testing/.tmp/amylee/3538.0/dist.x86_64/include’ -o OBJ.x86_64-unknown-linux-gnu/flag.o -c flag.c
gcc ‘-I/usr/local/grass-6.4.3svn/include’ ‘-I/home/madi/.grass6/addons/include’ ‘-I/home/madi/grassdata/nc_spm_08/testing/.tmp/amylee/3538.0/dist.x86_64/include’ -g -Wall -I/usr/local/include -I/usr/local/include -DPACKAGE="“grassmods”" ‘-I/usr/local/grass-6.4.3svn/include’ ‘-I/home/madi/.grass6/addons/include’ ‘-I/home/madi/grassdata/nc_spm_08/testing/.tmp/amylee/3538.0/dist.x86_64/include’ -o OBJ.x86_64-unknown-linux-gnu/load.o -c load.c
gcc ‘-I/usr/local/grass-6.4.3svn/include’ ‘-I/home/madi/.grass6/addons/include’ ‘-I/home/madi/grassdata/nc_spm_08/testing/.tmp/amylee/3538.0/dist.x86_64/include’ -g -Wall -I/usr/local/include -I/usr/local/include -DPACKAGE="“grassmods”" ‘-I/usr/local/grass-6.4.3svn/include’ ‘-I/home/madi/.grass6/addons/include’ ‘-I/home/madi/grassdata/nc_spm_08/testing/.tmp/amylee/3538.0/dist.x86_64/include’ -o OBJ.x86_64-unknown-linux-gnu/main.o -c main.c
gcc ‘-I/usr/local/grass-6.4.3svn/include’ ‘-I/home/madi/.grass6/addons/include’ ‘-I/home/madi/grassdata/nc_spm_08/testing/.tmp/amylee/3538.0/dist.x86_64/include’ -g -Wall -I/usr/local/include -I/usr/local/include -DPACKAGE="“grassmods”" ‘-I/usr/local/grass-6.4.3svn/include’ ‘-I/home/madi/.grass6/addons/include’ ‘-I/home/madi/grassdata/nc_spm_08/testing/.tmp/amylee/3538.0/dist.x86_64/include’ -o OBJ.x86_64-unknown-linux-gnu/rbtree.o -c rbtree.c
gcc ‘-I/usr/local/grass-6.4.3svn/include’ ‘-I/home/madi/.grass6/addons/include’ ‘-I/home/madi/grassdata/nc_spm_08/testing/.tmp/amylee/3538.0/dist.x86_64/include’ -g -Wall -I/usr/local/include -I/usr/local/include -DPACKAGE="“grassmods”" ‘-I/usr/local/grass-6.4.3svn/include’ ‘-I/home/madi/.grass6/addons/include’ ‘-I/home/madi/grassdata/nc_spm_08/testing/.tmp/amylee/3538.0/dist.x86_64/include’ -o OBJ.x86_64-unknown-linux-gnu/streams.o -c streams.c
gcc ‘-I/usr/local/grass-6.4.3svn/include’ ‘-I/home/madi/.grass6/addons/include’ ‘-I/home/madi/grassdata/nc_spm_08/testing/.tmp/amylee/3538.0/dist.x86_64/include’ -g -Wall -I/usr/local/include -I/usr/local/include -DPACKAGE="“grassmods”" ‘-I/usr/local/grass-6.4.3svn/include’ ‘-I/home/madi/.grass6/addons/include’ ‘-I/home/madi/grassdata/nc_spm_08/testing/.tmp/amylee/3538.0/dist.x86_64/include’ -o OBJ.x86_64-unknown-linux-gnu/thin.o -c thin.c
gcc ‘-L/usr/local/grass-6.4.3svn/lib’ ‘-L/home/madi/.grass6/addons/lib’ ‘-L/home/madi/grassdata/nc_spm_08/testing/.tmp/amylee/3538.0/dist.x86_64/lib’ -Wl,–export-dynamic -Wl,-rpath-link,/usr/local/grass-6.4.3svn/lib -L/usr/include/postgresql/libpq/ -o /home/madi/grassdata/nc_spm_08/testing/.tmp/amylee/3538.0/dist.x86_64/bin/r.stream.extract OBJ.x86_64-unknown-linux-gnu/close.o OBJ.x86_64-unknown-linux-gnu/del_streams.o OBJ.x86_64-unknown-linux-gnu/do_astar.o OBJ.x86_64-unknown-linux-gnu/flag.o OBJ.x86_64-unknown-linux-gnu/load.o OBJ.x86_64-unknown-linux-gnu/main.o OBJ.x86_64-unknown-linux-gnu/rbtree.o OBJ.x86_64-unknown-linux-gnu/streams.o OBJ.x86_64-unknown-linux-gnu/thin.o -lgrass_vect.6.4.3svn -lgrass_dbmibase.6.4.3svn -lgrass_gis.6.4.3svn -lgrass_datetime.6.4.3svn -lz -lgrass_dbmiclient.6.4.3svn -lgrass_dbmibase.6.4.3svn -lgrass_gis.6.4.3svn -lgrass_datetime.6.4.3svn -lz -lgrass_gis.6.4.3svn -lgrass_datetime.6.4.3svn -lz -lgrass_dgl.6.4.3svn -lgrass_dig2.6.4.3svn -lgrass_gis.6.4.3svn -lgrass_datetime.6.4.3svn -lz -lgrass_rtree.6.4.3svn -lgrass_gis.6.4.3svn -lgrass_datetime.6.4.3svn -lz -lgrass_linkm.6.4.3svn -lgrass_rtree.6.4.3svn -lgrass_dig2.6.4.3svn -lgrass_gis.6.4.3svn -lgrass_datetime.6.4.3svn -lz -lgrass_rtree.6.4.3svn -lgrass_dgl.6.4.3svn -lgrass_rtree.6.4.3svn -lgrass_linkm.6.4.3svn -lgrass_dbmiclient.6.4.3svn -lgrass_dbmibase.6.4.3svn -lgrass_gis.6.4.3svn -lgrass_datetime.6.4.3svn -lz -lgrass_gis.6.4.3svn -lgrass_datetime.6.4.3svn -lz -lgrass_dbmibase.6.4.3svn -lgrass_gis.6.4.3svn -lgrass_datetime.6.4.3svn -lz -L/usr/local/lib -lgdal -L/usr/local/lib -lgeos -lgeos_c -lgrass_dbmiclient.6.4.3svn -lgrass_dbmibase.6.4.3svn -lgrass_gis.6.4.3svn -lgrass_datetime.6.4.3svn -lz -lgrass_gis.6.4.3svn -lgrass_datetime.6.4.3svn -lz -lgrass_dbmibase.6.4.3svn -lgrass_gis.6.4.3svn -lgrass_datetime.6.4.3svn -lz -lgrass_gis.6.4.3svn -lgrass_datetime.6.4.3svn -lz -lm -lz
make htmlcmd
make[1]: Entering directory /home/madi/grassdata/nc_spm_08/testing/.tmp/amylee/3538.0/r.stream.extract' /usr/local/grass-6.4.3svn/include/Make/Grass.make:423: warning: overriding commands for target
/usr/local/grass-6.4.3svn/include/Make/Grass.make:414: warning: ignoring old commands for target /home/madi/grassdata/nc_spm_08/testing/.tmp/amylee/3538.0/dist.x86_64/bin' /usr/local/grass-6.4.3svn/include/Make/Module.make:25: warning: overriding commands for target
install’
/usr/local/grass-6.4.3svn/include/Make/Rules.make:99: warning: ignoring old commands for target install' make /home/madi/grassdata/nc_spm_08/testing/.tmp/amylee/3538.0/dist.x86_64/docs/html/r.stream.extract.html HTMLSRC=/home/madi/grassdata/nc_spm_08/testing/.tmp/amylee/3538.0/dist.x86_64/bin/r.stream.extract make[2]: Entering directory
/home/madi/grassdata/nc_spm_08/testing/.tmp/amylee/3538.0/r.stream.extract’
install’
if [ “/home/madi/grassdata/nc_spm_08/testing/.tmp/amylee/3538.0/dist.x86_64/bin/r.stream.extract” != “” ] ; then GISRC=/home/madi/grassdata/nc_spm_08/testing/.tmp/amylee/3538.0/dist.x86_64/demolocation/.grassrc64 GISBASE=/usr/local/grass-6.4.3svn PATH=“/home/madi/grassdata/nc_spm_08/testing/.tmp/amylee/3538.0/dist.x86_64/bin:$PATH” LD_LIBRARY_PATH=“/home/madi/grassdata/nc_spm_08/testing/.tmp/amylee/3538.0/dist.x86_64/bin:/usr/local/grass-6.4.3svn/lib:/usr/local/grass-6.4.3svn/lib” LC_ALL=C /home/madi/grassdata/nc_spm_08/testing/.tmp/amylee/3538.0/dist.x86_64/bin/r.stream.extract --html-description < /dev/null | grep -v ‘|’ > r.stream.extract.tmp.html ; true ; fi
/usr/local/grass-6.4.3svn/tools/mkhtml.sh r.stream.extract ; mkdir -p /home/madi/grassdata/nc_spm_08/testing/.tmp/amylee/3538.0/dist.x86_64/docs/html ; /usr/bin/install -c -m 644 r.stream.extract.tmp.html /home/madi/grassdata/nc_spm_08/testing/.tmp/amylee/3538.0/dist.x86_64/docs/html/r.stream.extract.html ; for file in *.png *.jpg ; do head -n 1 $file | grep ‘^#!’ > /dev/null ; if [ $? -ne 0 ] ; then /usr/bin/install -c -m 644 $file /home/madi/grassdata/nc_spm_08/testing/.tmp/amylee/3538.0/dist.x86_64/docs/html ; fi done 2> /dev/null ; true
make[2]: Leaving directory /home/madi/grassdata/nc_spm_08/testing/.tmp/amylee/3538.0/r.stream.extract' make[1]: Leaving directory
make mancmd
install’
/usr/local/grass-6.4.3svn/include/Make/Rules.make:99: warning: ignoring old commands for target install' make /home/madi/grassdata/nc_spm_08/testing/.tmp/amylee/3538.0/dist.x86_64/man/man1/r.stream.extract.1 MANSRC=/home/madi/grassdata/nc_spm_08/testing/.tmp/amylee/3538.0/dist.x86_64/docs/html/r.stream.extract.html make[2]: Entering directory
install’
mkdir -p /home/madi/grassdata/nc_spm_08/testing/.tmp/amylee/3538.0/dist.x86_64/man/man1
GRASS_PERL=/usr/bin/perl VERSION_NUMBER=6.4.3svn sh /usr/local/grass-6.4.3svn/tools/g.html2man /home/madi/grassdata/nc_spm_08/testing/.tmp/amylee/3538.0/dist.x86_64/docs/html/r.stream.extract.html /home/madi/grassdata/nc_spm_08/testing/.tmp/amylee/3538.0/dist.x86_64/man/man1/r.stream.extract.1 1
make[2]: *** [/home/madi/grassdata/nc_spm_08/testing/.tmp/amylee/3538.0/dist.x86_64/man/man1/r.stream.extract.1] Error 127
make[2]: Leaving directory /home/madi/grassdata/nc_spm_08/testing/.tmp/amylee/3538.0/r.stream.extract' make[1]: *** [mancmd] Error 2 make[1]: Leaving directory
make: *** [cmd] Error 2
ERROR: Compilation failed, sorry. Please check above error messages.
Thanks in advance for any hint…
cheers
madi
Margherita DI LEO
Postdoctoral Researcher
European Commission - DG JRC
Forest Resources and Climate
I-21020 Ispra (VA) - Italy - TP 261
Tel. +39 0332 78 3600
margherita.di-leo@jrc.ec.europa.eu
