It should be fixed now, please svn up & test a bunch.
Tested with d.barb and v.surf.icw, both from run the build
dir and after 'make install'. all seemed to be ok.
I also backported the update to g.manual so that it will work
with man and html help pages for your addon modules too.
GRASS> g.manual -m r.stack
"man g.addonmodule" still doesn't work; $MANPATH overrides
instead of adding to the path, and we'd have to move
$ADDONS/docs/man/ to $ADDONS/man/ to get it picked up
automatically. (one level above an entry in $PATH, or a sibling
directory of something ending in bin/. see /etc/manpath.config)
You can get around that with a symlink if you don't mind the
clutter.
dir and after ‘make install’. all seemed to be ok.
“man g.addonmodule” still doesn’t work; $MANPATH overrides
instead of adding to the path, and we’d have to move
You can get around that with a symlink if you don’t mind the
clutter.
Hamish
Margherita DI LEO
Postdoctoral Researcher
European Commission - DG JRC
Institute for Environment and Sustainability (IES). Unit H03 – FRC
Via Fermi, 2749
I-21027 Ispra (VA) - Italy - TP 261
Disclaimer: The views expressed are purely those of the writer and may not in any circumstance be regarded as stating an official position of the European Commission.
clutter.
Hamish
Margherita DI LEO
Via Fermi, 2749
Margherita DI LEO
Via Fermi, 2749
