[GRASS-dev] g.extension, svn, and Mac
I just learned yesterday, when I tried to install something from g.extension that:
  1. g.extension uses svn to download packages, and
  2. Apple stopped including svn with the current OS (10.15.x) and its developer tools
I don’t know if anyone else has run into this yet, but it could be an increasingly sticky issue going forward. Unless there are plans to change how g.extension gets packages, I suppose I need to include it in the Mac app bundle.
Has anyone else hit this yet?
Michael
C. Michael Barton
Director, Network for Computational Modeling in Social & Ecological Sciences
Head, Graduate Faculty in Complex Adaptive Systems Science
Arizona State University
voice: 480-965-6262 (SHESC), 480-965-8130/727-9746 (CSDC)
fax: 480-965-7671 (SHESC), 480-727-0709 (CSDC)
www: 'http://www.public.asu.edu/~cmbarton, https://complexity.asu.edu/csdc’
Perhaps a different issue, but I can install extensions, but only pure python-based extensions. Anything that requires compilation of C code fails.
For example, when using the latest GRASS GIS binary (7.9, 25th July 2020 build), this works with r.texture.tiled:
Fetching <r.texture.tiled> from GRASS GIS Addons repository (be patient)…
Compiling…
Installing…
Updating extensions metadata file…
Updating extension modules metadata file…
Installation of <r.texture.tiled> successfully finished
But for example, r.fill.gaps does not:
g.extension extension=r.fill.gaps
Fetching <r.fill.gaps> from GRASS GIS Addons repository (be patient)…
Compiling…
clang-10: warning: no such sysroot directory:
‘/Users/cmbarton/SDKs/MacOSX10.14.sdk’ [-Wmissing-sysroot]
cell_funcs.c:21:10: fatal error: ‘math.h’ file not found
#include <math.h>
1 error generated.
make: *** [OBJ.x86_64-apple-darwin19.5.0/cell_funcs.o] Error
1
ERROR: Compilation failed, sorry. Please check above error messages.
The 7.9-dev build throws an error because it appears to be still looking for components based on your system, specifically.,The 7.8.4 binary (16th July 2020 build) also throws the same error. I’m running the MacOS 10.15.6.
Steve
Michael
C. Michael Barton
grass-dev mailing list
grass-dev@lists.osgeo.org
https://lists.osgeo.org/mailman/listinfo/grass-dev
Steven,
What happens if you open a terminal window and type ‘svn’ followed by a return?
Michael
C. Michael Barton
Compiling…
Installing…
Compiling…
#include <math.h>
1 error generated.
1
Steve
Michael
C. Michael Barton
Steve,
I just now posted a new updated GRASS 7.9dev that includes svn in the app. It solved the g.extension problem for me. Can you test and see if it solves it for you too?
Michael
C. Michael Barton
On Aug 4, 2020, at 11:59 AM, Michael Barton <Michael.Barton@asu.edu> wrote:
I’m pretty sure this happened when I installed developer tools 11.5
I want to make sure that anyone using the binaries can do so without having to separately install any dependencies. So I’ll see what happens if I just include svn in the app. I will need to test on a system that suffers from this lack.
Michael
C. Michael Barton
On Aug 4, 2020, at 11:56 AM, Steven Pawley <dr.stevenpawley@gmail.com> wrote:
Hi Michael,
Right, I do have svn installed via Homebrew (I get 'Type ‘svn help’ for usage.’), so that probably explains why g.extension works for me overall, apart from the issue with finding the MacOS SDK.
Steve
On Aug 4, 2020, at 11:27 AM, Michael Barton <Michael.Barton@asu.edu> wrote:
Steven,
Michael
C. Michael Barton
Compiling…
Installing…
Compiling…
#include <math.h>
1 error generated.
1
Steve
Michael
C. Michael Barton
Hi Michael,
Thanks for updating. I can still install python-based extensions without any error, however I still get the same error for compiled code:
Compiling…
#include <math.h>
1 error generated.
make: *** [OBJ.x86_64-apple-darwin19.6.0/cell_funcs.o] Error
1
Steve
On Aug 5, 2020, at 2:00 PM, Michael Barton <Michael.Barton@asu.edu> wrote:
Steve,
Michael
C. Michael Barton
Michael
C. Michael Barton
Hi Michael,
Steve
Steven,
Michael
C. Michael Barton
Compiling…
Installing…
Compiling…
#include <math.h>
1 error generated.
1
Steve
Michael
C. Michael Barton
This error implies that you need the 10.14.sdk folder. Why would that be so? That would be a problem.
Michael
C. Michael Barton
On Aug 5, 2020, at 2:39 PM, Steven Pawley <dr.stevenpawley@gmail.com> wrote:
Hi Michael,
Compiling…
#include <math.h>
1 error generated.
1
Steve
Steve,
Michael
C. Michael Barton
Michael
C. Michael Barton
Hi Michael,
Steve
Steven,
Michael
C. Michael Barton
Compiling…
Installing…
Compiling…
#include <math.h>
1 error generated.
1
Steve
Michael
C. Michael Barton
I’m on 10.15 (on a relatively new Mac) and officially Xcode only ships with the latest SDK. I think unofficially it might be possible to copy older SDKs into the Xcode app bundle but presumably not ideal.
Michael
C. Michael Barton
Hi Michael,
Compiling…
#include <math.h>
1 error generated.
1
Steve
Steve,
Michael
C. Michael Barton
Michael
C. Michael Barton
Hi Michael,
Steve
Steven,
Michael
C. Michael Barton
Compiling…
Installing…
Compiling…
#include <math.h>
1 error generated.
1
Steve
Michael
C. Michael Barton
It’s better if the binary does not need any SDK so people can use it without installing Xcode. It really shouldn’t be necessary. There should be all the tools needed for compiling within the miniconda package installed in the app. I’m pretty sure I know what line in configure is causing this. Need to see how to get around it.
Michael
C. Michael Barton
Michael
C. Michael Barton
Hi Michael,
Compiling…
#include <math.h>
1 error generated.
1
Steve
Steve,
Michael
C. Michael Barton
Michael
C. Michael Barton
Hi Michael,
Steve
Steven,
Michael
C. Michael Barton
Compiling…
Installing…
Compiling…
#include <math.h>
1 error generated.
1
Steve
Michael
C. Michael Barton
This has to do with some kind of change in master (not in v. 7.8.4dev as of 25 July) that caused configure to fail with a bogus missing zlib message. Nicklas found a workaround by adding
export CONDA_BUILD_SYSROOT=[hard path to SDK]
to the configure script. But that is now causing problems with compiling through g.extension. So we need to find out why configure is failing.
I’ve filed a bug report at: https://github.com/OSGeo/grass/issues/880
Michael
C. Michael Barton
Michael
C. Michael Barton
Michael
C. Michael Barton
Hi Michael,
Compiling…
#include <math.h>
1 error generated.
1
Steve
Steve,
Michael
C. Michael Barton
Michael
C. Michael Barton
Hi Michael,
Steve
Steven,
Michael
C. Michael Barton
Compiling…
Installing…
Compiling…
#include <math.h>
1 error generated.
1
Steve
Michael
C. Michael Barton
Michael,
You may try without setting SDK at all (remove --with-macosx-sdk= and CONDA_BUILD_SYSROOT), but I doubt it will. CONDA_BUILD_SYSROOT is not a workaround, it’s needed for conda.
(If indeed necessary to set SDK, it might be better to use:
CONDA_BUILD_SYSROOT=$(xcrun --show-sdk-path) to use present SDK while building GRASS, but make sure to set MACOSX_DEPLOYMENT_TARGET.)
What seems to work for compiling extensions, is modifying the file:
/Applications/GRASS-7.9.app/Contents/Resources/include/Make/Platform.make
deleting the 4 instances of the text:
-isysroot /Users/cmbarton/SDKs/MacOSX10.14.sdk
I cannot however tell whether this works without Xcode.
Best,
Nicklas
Michael
C. Michael Barton
Michael
C. Michael Barton
Michael
C. Michael Barton
Hi Michael,
Compiling…
#include <math.h>
1 error generated.
1
Steve
Steve,
Michael
C. Michael Barton
Michael
C. Michael Barton
Hi Michael,
Steve
Steven,
Michael
C. Michael Barton
Compiling…
Installing…
Compiling…
#include <math.h>
1 error generated.
1
Steve
Michael
C. Michael Barton
Following short script may be executed before dmg packaging to remove -isysroot:
#!/bin/bash
FILE=“/Applications/GRASS-7.9.app/Contents/Resources/include/Make/Platform.make”
sed -i .bak ‘s|-isysroot /Users/cmbarton/SDKs/MacOSX10.14.sdk||g’ $FILE
On 6 Aug 2020, at 11:07, Nicklas Larsson <n_larsson@yahoo.com> wrote:
Michael,
Best,
Nicklas
Michael
C. Michael Barton
Michael
C. Michael Barton
Michael
C. Michael Barton
Hi Michael,
Compiling…
#include <math.h>
1 error generated.
1
Steve
Steve,
Michael
C. Michael Barton
Michael
C. Michael Barton
Hi Michael,
Steve
Steven,
Michael
C. Michael Barton
Compiling…
Installing…
Compiling…
#include <math.h>
1 error generated.
1
Steve
Michael
C. Michael Barton
Steven,
Can you try this with the GRASS 7.8.4dev binary I have on the Mac site? I’d like to know if this affects all binaries or just 7.9
Thanks
Michael
C. Michael Barton
Hi Michael,
Compiling…
#include <math.h>
1 error generated.
1
Steve
Steve,
Michael
C. Michael Barton
Michael
C. Michael Barton
Hi Michael,
Steve
Steven,
Michael
C. Michael Barton
Compiling…
Installing…
Compiling…
#include <math.h>
1 error generated.
1
Steve
Michael
C. Michael Barton
Hi Nicklas,
I’ve been building these packages for a couple years with Anaconda and never needed to export CONDA_BUILD_SYSROOT previously. And I don’t need it to build 7.8. So something has changed that requires this in 7.9.
The issue with compiling extensions may have existed previously and just no one reported it. I’m trying to check this now. This was the case with old non-inclusive package. You had to have the command line dev tools installed. The new apps are supposed to fix that by having tools needed for compiling installed inside the app.
The reason to build with Anaconda is that I wanted to create an all-inclusive binary package that would work as most Mac users expect, without having to install anything extra. This could not be done with the old (and largely obsolete) packaging tools that come with GRASS. There may be other ways to do it, but Anaconda works pretty well and is comparatively easy to manage, especially for getting all of the many dependencies that GRASS needs without me having to compile and update them from scratch.
Maybe there is no need to point to an SDK at all, as you mention. I’ve been doing it as a legacy from old build protocols that helped ensure that GRASS would be backward compatible with at least a few older OS versions. Maybe with everything inside, it isn’t needed and just mucks things up. So I’ll try building without it. If CONDA_BUILD_SYSROOT is now required, could it point to the /Contents/Resources folder inside the app? This should have all the needed compiling tools (in /bin, /include, /lib, etc).
While we can tell Mac users that they need to install command line tools (or equivalent in Homebrew or Macports) if they want to compile some extensions, it will be better and cleaner if there is a way to make all this happen in the app.
Michael
C. Michael Barton
On Aug 6, 2020, at 2:07 AM, Nicklas Larsson <n_larsson@yahoo.com> wrote:
Michael,
Best,
Nicklas
Michael
C. Michael Barton
Michael
C. Michael Barton
Michael
C. Michael Barton
Hi Michael,
Compiling…
#include <math.h>
1 error generated.
1
Steve
Steve,
Michael
C. Michael Barton
Michael
C. Michael Barton
Hi Michael,
Steve
Steven,
Michael
C. Michael Barton
Compiling…
Installing…
Compiling…
#include <math.h>
1 error generated.
1
Steve
Michael
C. Michael Barton
Michael,
On 6 Aug 2020, at 19:35, Michael Barton <Michael.Barton@asu.edu> wrote:
Hi Nicklas,
The only thing that has changed lately, is that now CC is configurable, before it was static (“gcc”, with your previous patch "clang”). This in itself may, somehow indirect lead to the requirement of CONDA_BUILD_SYSROOT, I don’t know. I do know that a configurable CC is the way it should have been from start.
Setting a hard path to "–with-macosx-sdk=“ will lead to setting -isysroot in Platform.make. So, for as long as you have built in this way, compiling extensions was probably broken for other users. Deleting sysroot (pre-distribution) from that file may be the solution for this.
I understand you perfectly and support your goal. Presently, conda is the best (only) way for this aims.
This may be a more general way to set
which with 10.15 (and probably back a few versions) will resolve to:
/Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX.sdk
But you cannot include SDK in binary bundle (legal concerns).
I haven’t been able to figure out actual differences/advantages with using only MACOSX_DEPLOYMENT_TARGET vs. and/or setting -isysroot. But if MACOSX_DEPLOYMENT_TARGET only is enough, that may be the way to go.
I would suggest, now for a start, to keep the 10.14 SDK and CONDA_BUILD_SYSROOT as is, and apply my little sysroot delete script before distribution.
/ Nicklas
Michael
C. Michael Barton
Michael,
Best,
Nicklas
Michael
C. Michael Barton
Michael
C. Michael Barton
Michael
C. Michael Barton
Hi Michael,
Compiling…
#include <math.h>
1 error generated.
1
Steve
Steve,
Michael
C. Michael Barton
Michael
C. Michael Barton
Hi Michael,
Steve
Steven,
Michael
C. Michael Barton
Compiling…
Installing…
Compiling…
#include <math.h>
1 error generated.
1
Steve
Michael
C. Michael Barton
Hi Michael,
Yes, the 7.8.4.dev binary has the same issue in that it is also looking for the /Users/cmbarton/SDKs/MacOSX10.14.sdk SDK.
Steve
On Aug 6, 2020, at 11:22 AM, Michael Barton <Michael.Barton@asu.edu> wrote:
Steven,
Thanks
Michael
C. Michael Barton
Hi Michael,
Compiling…
#include <math.h>
1 error generated.
1
Steve
Steve,
Michael
C. Michael Barton
Michael
C. Michael Barton
Hi Michael,
Steve
Steven,
Michael
C. Michael Barton
Compiling…
Installing…
Compiling…
#include <math.h>
1 error generated.
1
Steve
Michael
C. Michael Barton
Thanks. That clarifies things somewhat.
Michael
C. Michael Barton
On Aug 6, 2020, at 12:49 PM, Steven Pawley <dr.stevenpawley@gmail.com> wrote:
Hi Michael,
Steve
Steven,
Thanks
Michael
C. Michael Barton
Hi Michael,
Compiling…
#include <math.h>
1 error generated.
1
Steve
Steve,
Michael
C. Michael Barton
Michael
C. Michael Barton
Hi Michael,
Steve
Steven,
Michael
C. Michael Barton
Compiling…
Installing…
Compiling…
#include <math.h>
1 error generated.
1
Steve
Michael
C. Michael Barton
Nicklas,
I’ve done some tests and can give more info. I will put this all into the GitHub issue for the record.
Michael
C. Michael Barton
On Aug 6, 2020, at 11:18 AM, Nicklas Larsson <n_larsson@yahoo.com> wrote:
Michael,
Hi Nicklas,
/ Nicklas
Michael
C. Michael Barton
Michael,
Best,
Nicklas
Michael
C. Michael Barton
Michael
C. Michael Barton
Michael
C. Michael Barton
Hi Michael,
Compiling…
#include <math.h>
1 error generated.
1
Steve
Steve,
Michael
C. Michael Barton
Michael
C. Michael Barton
Hi Michael,
Steve
Steven,
Michael
C. Michael Barton
Compiling…
Installing…
Compiling…
#include <math.h>
1 error generated.
1
Steve
Michael
C. Michael Barton
