[GRASS-dev] g.extension
I just tried out g.extension, attempting to put the new extension in the proper place for a Mac. I regularly compile GRASS.
Any idea why I got this error result?
g.extension extension=r.convert svnurl=grass - Revision 74509: /grass-addons/grass7 prefix=/Library/Application\ Support/GRASS/7.0/Modules/bin menuitem=raster,Develop raster map
'/Library/Application\ Support/GRASS/7.0/Modules/bin ' created
Fetching 'r.convert' from GRASS-Addons SVN (be patient)...
A r.convert/r.convert
A r.convert/r.convert.all
Checked out revision 39797.
Compiling 'r.convert'...
make: *** No targets specified and no makefile found. Stop.
ERROR: Compilation failed, sorry. Please check above error messages.
Michael
On Wed, Nov 25, 2009 at 5:32 PM, Michael Barton <michael.barton@asu.edu> wrote:
svnurl=https://svn.osgeo.org/grass/grass-addons/grass7 prefix=/Library/Application\
As Glynn mentioned yesterday, no more support in GRASS 7
for shell script installation:
file *
r.convert: POSIX shell script text executable
r.convert.all: POSIX shell script text executable
(also the extension is lacking a Makefile).
I think that the g.extension version in GRASS 7 should trap this
somehow (not sure how, perhaps simply via mime type test of
the file(s) to install?).
