There seems to be a problem with addons metadata when installing using g.extension. Installing of addons is successful, but with the following error message:
On Mon, Aug 3, 2015 at 4:06 PM, Paulo van Breugel
error message:
> error message:
> WARNING: Unable to parse
> 'https://svn.osgeo.org/grass/grass-addons/grass7/modules.xml’: syntax
error:
> line 1, column 49
The file is simply not (yet) there after the recent server hardware
migration.
Work in progress...
Ah, ok, good to know.. so no need to report these issues
On Mon, Aug 3, 2015 at 7:08 PM, Paulo van Breugel
> error message:
migration.
error message:
migration.
On Tue, Aug 11, 2015 at 5:24 PM, Markus Neteler <neteler@osgeo.org> wrote:
PS: Martin Landa solved the remaining issues + added the page subtitles
And also documented the process and script used [1], so if somebody would
like to improve it, e.g. order addons by keywords [2] or fix description
for module groups such as r.green [3, 4], it's now possible.
