[GRASS-dev] g.gisenv in gui
Found another minor item that a small change could improve.
g.gisenv does not behave like other GRASS commands in that you cannot launch the autogenerated gui by typing ‘g.gisenv’ from the command line. Instead, you get the current environment settings. You can only get the gui if you run it through some special processing in the GUI. Likewise, you can’t get it to print out current environment settings from the gui unless you do some tricks with its execution.
To behave more ‘normally’ it needs a –p flag. Then…
g.gisenv → autogenerated gui
g.gisenv –p → print current settings.
I suppose that this would break a bunch of scripts, but it would be nice if it could work consistently with other commands.
Michael
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
launch the autogenerated gui by typing Œg.gisenv¹ from the command
for a GUI just launch with:
  g.gisenv --ui
use that as the menu command.
A number of modules work like this without command line args.
Likewise, you can¹t get it to print out current environment settings
g.gisenv store="" --ui
[Run]
Probably a nice GUI frontend should be used for that, vs exposing the
user to the raw g.gisenv GUI.
Hamish
Hamish,
Thanks for this info. But...
  g.gisenv --ui
This does work to get the gui from the command line
[Run]
This doesn't work to get the settings printed to stdout. It just launches
the gui.
Michael
phone: 480-965-6213
fax: 480-965-7671
  g.gisenv --ui
In general, modules where all options have a reasonable default value
work this way. E.g. "d.erase" is equivalent to "d.erase color=white"
rather than to "d.erase --ui".
the autogenerated gui by typing Œg.gisenv¹ from the command line. Instead,
See Hamish's reply.
AFAICT, the problem with g.gisenv is that it checks for argc==1 before
calling G_parser(), so e.g. "g.gisenv --quiet" causes that check to
fail.
What it should probably do is to call G_parser() unconditionally, then
check for:
  if (!get->answer && !set->answer && !store_opt->answer)
To behave more Œnormally¹ it needs a ­p flag. Then...
g.gisenv -> autogenerated gui
g.gisenv ­p -> print current settings.
I suspect that this is unnecessary if the no-arguments check is fixed.
I don't quite follow the proposed changes below, but I trust you that this
will probably fix things.
Michael
the autogenerated gui by typing �g.gisenv� from the command line. Instead,
See Hamish's reply.
Likewise, you can�t get
fail.
check for:
To behave more �normally� it needs a �p flag. Then...
g.gisenv �p -> print current settings.
phone: 480-965-6213
fax: 480-965-7671
Michael:
Glynn:
fail.
g.gisenv just outputs to stdout. There's no G_message() or G_percent()
or anything that would use --quiet. Just treat g.gisenv like it were
"ls" and send the output to a buffer or a temp file.
for example:
import os
prog = os.popen("g.gisenv")
print prog.read()
LOCATION_NAME='spearfish60';
MAPSET='user1';
DIGITIZER='none';
GISDBASE='/home/hamish/grassdata';
DEBUG='0';
MONITOR='x0';
GRASS_GUI='text';
# for shell vars (replace grep filter with python version)
import os
prog = os.popen("set | grep '^GIS\|^GRASS_'")
print prog.read()
nothing more to do here AFAICS....
Hamish
Hamish wrote:
Michael:
Glynn:
> fail.
The point is that *any* options (even ones which have no effect, e.g.
--quiet or --verbose) caused the argc==1 check to fail.
I've now changed it so that if you specify neither get= nor set=, it
will print the current settings.
Apart from not being confused by --quiet etc, you should now be able
to use "g.gisenv store=mapset" to list the VAR file.
