Hi Veronica,
On Tue, Aug 8, 2017 at 3:46 PM, Veronica Andreo <veroandreo@gmail.com> wrote:
I’ve also experienced the freezing issue (dunno if it the same thing or not). Here, the rendering freezes if strds has more than 500 maps. I do not even get to the export part. Cancel does not close it, so I have to kill it (trunk r71319).
Same problem here, when I reach 502 maps raise the following exception:
File "/usr/lib/python2.7/site-packages/wx-3.0-gtk2/wx/_core.py", line 16762, in <lambda>
File "/home/pietro/.local/grass-7.3.svn/gui/wxpython/animation/frame.py", line 194, in SetAnimations
File "/home/pietro/.local/grass-7.3.svn/gui/wxpython/animation/controller.py", line 305, in SetAnimations
File "/home/pietro/.local/grass-7.3.svn/gui/wxpython/animation/controller.py", line 328, in _setAnimations
File "/home/pietro/.local/grass-7.3.svn/gui/wxpython/animation/controller.py", line 407, in _updateBitmapData
File "/home/pietro/.local/grass-7.3.svn/gui/wxpython/animation/provider.py", line 234, in Load
File "/home/pietro/.local/grass-7.3.svn/gui/wxpython/animation/provider.py", line 366, in Render
File "/usr/lib64/python2.7/multiprocessing/__init__.py", line 218, in Queue
File "/usr/lib64/python2.7/multiprocessing/queues.py", line 63, in __init__
File "/usr/lib64/python2.7/multiprocessing/synchronize.py", line 147, in __init__
File "/usr/lib64/python2.7/multiprocessing/synchronize.py", line 75, in __init__
OSError: [Errno 24] Too many open files
But checking the number of opened file on my system, it seems two order lower than the maximum:
$ cat /proc/sys/fs/file-nr
23422 0 1628292
$ cat /proc/sys/fs/file-max
1628292
I’ve attached also the complete log of the command in DEBUG mode, but I was not able to understand where the problem could be. I’ve also rebooted just to be sure that the system was fresh, but again after 502 maps it breaks with the same error.
Any ideas?
Pietro
(attachments)
log_gui_animation.7z (2.36 KB)
