Hi devs,
sorry to bother…
Can anybody please share a .gxm file with an example for using r.mapcalc in a loop in the g.gui.gmodeler? I was able to do simple stuff with loops and say r.info or r.stats, but just can’t figure out the way to do even a simple operation with r.mapcalc in a loop… maybe too tired already…
I also found this video, but it is for grass 6 and does not use loops: https://www.youtube.com/watch?v=jaMyFQholMQ
Thanks much in advance!
Vero
On 4 November 2015 at 04:55, Veronica Andreo <veroandreo@gmail.com> wrote:
Hi devs,
sorry to bother...
say r.info or r.stats, but just can't figure out the way to do even a simple
operation with r.mapcalc in a loop... maybe too tired already...
here you are... please if you are able, provide some documentation for
g.gui.gmodeler, it is really needed
Vero
ciao
Luca
http://gis.cri.fmach.it/delucchi/
www.lucadelu.org
(attachments)
test.gxm (6.91 KB)
Ciao Luca!
Thanks for the example!
Did it work for you?? When I try to validate it, I get
Model is not valid.
r.mapcalc: undefined variable ‘ndvi * 0.0001’
whatever operation I write in the right part of the expression.
The only thing that gives me a valid model is %map = %map.
Can anybody explain how it should be done or what are we missing there, please???
I really need this for a GUI based course I have to teach next week (students use windows and know nothing of programming). Any other suggestion is more than welcome!
Vero
2015-11-04 4:53 GMT-03:00 Luca Delucchi <lucadeluge@gmail.com>:
Hi devs,
sorry to bother…
here you are… please if you are able, provide some documentation for
Vero
ciao
Luca
www.lucadelu.org
On 4 November 2015 at 16:58, Veronica Andreo <veroandreo@gmail.com> wrote:
Ciao Luca!
ciao vero,
with a small workaround yes
Model is not valid.
r.mapcalc: undefined variable 'ndvi * 0.0001'
I got the same
but this is not correct... there are some bugs in the modeler [0]
please???
nothing, but to have the script working properly you have to modify
the code from Python editor, you have to remove the wrong quotes [0],
and I have to obtain something similar to the attached python script.
Next week? You have plenty of time, I learned the Modeler (and how to
fix problems) in one night, so relax your self
Vero
[0] https://trac.osgeo.org/grass/ticket/2782
ciao
Luca
www.lucadelu.org
(attachments)
test.py (4.85 KB)
