[GRASS-dev] g.gui.metadata and wxgui addons in GRASS 7.1
I just tried to install g.gui.metadata addon with limited success.
No AddOn appears under wxGUI when I run g.extension from the GUI (while e.g. raster addons do show up). Is this probably do to the path in the AddOn repo (which starts with gui and not wxGUI). All other tree elements in g.extension are equal to folder names in the repository…
So, I finally compiled g.gui.extension from source after installing the dependencies.
Now, g.gui.metadata is available, but does not start:
File “/usr/local/grass-7.1.svn/scripts/g.gui.metadata”,
line 1246, in
main()
line 1240, in main
MAINFRAME = MdMainFrame()
line 88, in init
self.onInitEditor()
line 724, in onInitEditor
self.MdDataCatalogPanelLeft =
MdDataCatalog(self.leftPanel)
line 836, in init
self.InitTreeItems()
line 860, in InitTreeItems
self.initTemporalTree(location=location,
mapset=self.mapset)
line 923, in initTemporalTree
if self.itemExists(ml[2], varmapset) == False:
File
“/usr/local/grass-7.1.svn/gui/wxpython/lmgr/datacatalog.py”,
line 213, in itemExists
item, cookie = self.GetFirstChild(root)
File "/usr/lib/python2.7/dist-
packages/wx-2.8-gtk2-unicode/wx/_controls.py", line 5409, in
GetFirstChild
return controls.TreeCtrl_GetFirstChild(*args,
**kwargs)
ValueError: invalid null reference in method
‘TreeCtrl_GetFirstChild’, expected argument 2 of type
‘wxTreeItemId const &’
Stefan
Dear Stefan,
Thanks for bug report. I have done few changes(r65990) which should help but the installation from add-ons still doesn’t work properly[1].
2015-08-20 14:41 GMT+02:00 Blumentrath, Stefan <Stefan.Blumentrath@nina.no>:
line 1246, in
main()
line 1240, in main
line 88, in init
self.onInitEditor()
line 836, in init
mapset=self.mapset)
File
GetFirstChild
**kwargs)
Best
Matej
[1] https://lists.osgeo.org/pipermail/grass-dev/2015-August/076034.html
Hi Matej,
I just checked out your new revision. Now I get on sudo make MODULE_TOPDIR=/usr/local/grass-7.1.svn/:
make[1]: Entering directory `/data/src/grass7_addons/gui/wxpython/wx.metadata/g.gui.metadata’
if [ “/usr/local/grass-7.1.svn/scripts/g.gui.metadata” != “” ] ; then GISRC=/usr/local/grass-7.1.svn/demolocation/.grassrc71 GISBASE=/usr/local/grass-7.1.svn PATH=“/usr/local/grass-7.1.svn/bin:/usr/local/grass-7.1.svn/bin:/usr/local/grass-7.1.svn/scripts:$PATH” PYTHONPATH=“/usr/local/grass-7.1.svn/etc/python:/usr/local/grass-7.1.svn/gui/wxpython:$PYTHONPATH” LD_LIBRARY_PATH=“/usr/local/grass-7.1.svn/bin:/usr/local/grass-7.1.svn/scripts:/usr/local/grass-7.1.svn/lib:/usr/local/grass-7.1.svn/lib:” LC_ALL=C /usr/local/grass-7.1.svn/scripts/g.gui.metadata --html-description < /dev/null | grep -v ‘|’ > g.gui.metadata.tmp.html ; fi
File “/usr/local/grass-7.1.svn/scripts/g.gui.metadata”, line 27, in
sys.path.insert(2, os.path.join(os.getenv(‘GRASS_ADDON_BASE’), ‘etc’, ‘wx.metadata’, ‘mdlib’))
File “/usr/lib/python2.7/posixpath.py”, line 77, in join
elif path == ‘’ or path.endswith(‘/’):
AttributeError: ‘NoneType’ object has no attribute ‘endswith’
make[1]: *** [g.gui.metadata.tmp.html] Error 1
rm g.gui.metadata.tmp.html
make[1]: Leaving directory `/data/src/grass7_addons/gui/wxpython/wx.metadata/g.gui.metadata’
I did not update my GRASS 7.1 installation (it is r65797)…
Stefan
Dear Stefan,
line 1246, in
main()
line 1240, in main
line 88, in init
self.onInitEditor()
line 836, in init
mapset=self.mapset)
File
GetFirstChild
**kwargs)
Best
Matej
Hi Stephan,
2015-08-21 22:08 GMT+02:00 Blumentrath, Stefan <Stefan.Blumentrath@nina.no>:
Hi Matej,
Problem was that I never try make with sudo. I am not sure why it has effect. Problem should be fixed in r66007.
thank you for testing
Best
Matej
Hi Matej,
Yes, thanks it does compile now.
And when I run g.gui.metadata the GUI starts although I get this:
Initialize of temporal tree catalogue error: < in method ‘TreeCtrl_GetFirstChild’, expected argument 2 of type ‘wxTreeItemId const &’ >
Reason: in method ‘TreeCtrl_GetFirstChild’, expected argument 2 of type ‘wxTreeItemId const &’
File “/usr/local/grass-7.1.svn/scripts/g.gui.metadata”, line 958, in initTemporalTree
if self.itemExists(ml[2], varmapset) is False:
File “/usr/local/grass-7.1.svn/gui/wxpython/lmgr/datacatalog.py”, line 213, in itemExists
File “/usr/lib/python2.7/dist-packages/wx-2.8-gtk2-unicode/wx/_controls.py”, line 5409, in GetFirstChild
return controls.TreeCtrl_GetFirstChild(*args, **kwargs)
TypeError: in method ‘TreeCtrl_GetFirstChild’, expected argument 2 of type ‘wxTreeItemId const &’
I can browse the maps in my mapset and the pen and the “template” button get active. Yet, when I click on “template” I get:
WARNING: Epsg code cannot be identified
File “/usr/local/grass-7.1.svn/scripts/g.gui.metadata”, line 291, in onCreateTemplate
if self.onEdit():
File “/usr/local/grass-7.1.svn/scripts/g.gui.metadata”, line 303, in onEdit
ok = self.editMapMetadata()
File “/usr/local/grass-7.1.svn/scripts/g.gui.metadata”, line 648, in editMapMetadata
self.xmlPath = self.mdCreator.saveXML(self.mdDestination, self.nameTMPteplate, self)
File “/usr/local/grass-7.1.svn/etc/wx.metadata/mdlib/mdgrass.py”, line 513, in saveXML
profile = env.get_template(self.profilePath)
File “/usr/local/lib/python2.7/dist-packages/Jinja2-2.9.dev-py2.7.egg/jinja2/environment.py”, line 812, in get_template
return self._load_template(name, self.make_globals(globals))
File “/usr/local/lib/python2.7/dist-packages/Jinja2-2.9.dev-py2.7.egg/jinja2/environment.py”, line 774, in _load_template
cache_key = self.loader.get_source(self, name)[1]
File “/usr/local/lib/python2.7/dist-packages/Jinja2-2.9.dev-py2.7.egg/jinja2/loaders.py”, line 187, in get_source
raise TemplateNotFound(template)
jinja2.exceptions.TemplateNotFound: etc/wx.metadata/profiles/basicProfile.xml
The location was defined using an EPSG code (25632). It is a standard ETRS/UTM based CRS which is quite common for the western to central parts of Europe (and INSPIRE compliant)…
Anyway, the first glimpse I got from g.gui.metadata looked promising! Thanks for your work on that!
Stefan
Hi Stephan,
Hi Matej,
Best
Matej
Hi Stephan,
if self.onEdit():
Current revision is 66011. Before was everything defined fixedly to grass addons environment/base. Now it should work in all way of installation.
please try:
sudo make MODULE_TOPDIR=/usr/local/grass-7.1.svn install
folders with metadata libs, profiles and configure files need make install.
This warning does not affect for something important. Only auto identifying EPSG from WKT proj is not successful which means that the metadata attribute has not value. I changed warning to message because a lots of attributes cannot be filled from r/v.info.
big thanks for your endurance :slight_smile:
Matej
