[GRASS-dev] G_legal_filename and "/"
IMHO "/" character is legal character in file name. I suggest change
line 43 in lib/gis/legal_filename.c:
- if (*s == '/' || *s == '"' || *s == '\'' || *s <= ' ' ||
+ if (*s == '"' || *s == '\'' || *s <= ' ' ||
What do you think?
Jachym
Jachym Cepicky
e-mail: jachym.cepicky gmail com
URL: http://les-ejk.cz
GPG: http://www.les-ejk.cz/pgp/jachym_cepicky-gpg.pub
Je-Báchym Èepický wrote:e-A
What do you think?
No, "/" most definitely isn't a legal character in a filename, as it's
used as a directory separator on all supported platforms. It's legal
in a *pathname*, but that isn't what G_legal_filename() is meant for.
hi Glynn,
2007/2/3, Glynn Clements <glynn@gclements.plus.com>:
> What do you think?
While using g.pnmcomp with output file specified by full path (e.g.
"/tmp/out.png"), I get the warning about Illegal character in file
name.
How to avoid this problem?
Thanks
Jachym
Jachym Cepicky
> > What do you think?
name.
That's because I added bogus "gisprompt" definitions to the output=
and outmask= options, so the parser thinks that these options are
supposed to be map names. Fixed in CVS.
