`g.list` in G71 prints unqualified map names, why?
$ g.list vect
Praha
silnice
BazinyARaseliniste
Hranice
KladyZakladnichMap
The user need to use `-m` flag to understand from which mapset the map is.
$ g.list vect -m
Praha@martin
silnice@martin
BazinyARaseliniste@PERMANENT
I would suggest to print fully-qualified names by default. Any opinion? Martin
Martin Landa * http://geo.fsv.cvut.cz/gwiki/Landa *
http://www.gismentors.eu/mentors/landa
2014-10-27 21:01 GMT+01:00 Martin Landa <landa.martin@gmail.com>:
If you agree I would vote for reverting logic of -m flag to
Print unqualified map names (without mapsets)
Martin
On 28 October 2014 10:44, Martin Landa <landa.martin@gmail.com> wrote:
Hi
+1
Martin
ciao
Luca
http://gis.cri.fmach.it/delucchi/
www.lucadelu.org
IMO, printing fully-qualified names by default can be too much information in terminal and make it uncomfortable to read map names only. Currently, it prints fully-qualified names whenever maps cannot be identified by their unqualified names (e.g., two maps with the same name in multiple mapsets).
Huidae
Hi
+1
Martin
ciao
Luca
www.lucadelu.org
grass-dev mailing list
grass-dev@lists.osgeo.org
On Tue, Oct 28, 2014 at 1:05 PM, Huidae Cho <grass4u@gmail.com> wrote:
Maybe there was a discussion already about this, but another option is to
use -p as default (so that we actually see the mapsets) and add new flag
-g as shell script style? So that the default would be the same as g.list
before?
If I should decide between with/without mapset (the original question), I
think by default the mapset should be printed. The mapset information is
more important for me than the clutter it causes.
Anna
Huidae
> Hi,
Hi
opinion? Martin
+1
> Martin
ciao
Luca
www.lucadelu.org
-p as default is only good for the command line because in python scripts, you need more typing. The previous discussion was about making this module as friendly as possible both in the command line and scripting environments.
Reverting -m flag is fine with me unless anyone has strong arguments against it.
On Tue, Oct 28, 2014 at 3:48 PM, Anna Petrášová <kratochanna@gmail.com> wrote:
Maybe there was a discussion already about this, but another option is to use -p as default (so that we actually see the mapsets) and add new flag -g as shell script style? So that the default would be the same as g.list before?
If I should decide between with/without mapset (the original question), I think by default the mapset should be printed. The mapset information is more important for me than the clutter it causes.
Anna
Huidae
Hi
+1
Martin
ciao
Luca
www.lucadelu.org
