[GRASS-dev] g.mapsets, print only accessible mapsets
is there a way how to determine if a mapset is accessible without need
to switch 'g.mapset name' -> 'ERROR: You don't have permission to use
this mapset'. If not maybe new flag for g.mapsets would make sense?
-a 'List all accessible mapsets'
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa *
Martin,
in libgis I see
* G__mapset_permissions (mapset)
* returns: 1 mapset exists, and user has permission
* 0 mapset exists, BUT user denied permission
* -1 mapset does not exist
could that help (in modified form)?
On Thu, Mar 20, 2008 at 2:49 PM, Martin Landa <landa.martin@gmail.com> wrote:
Martin
grass-dev mailing list
grass-dev@lists.osgeo.org
Open Source Geospatial Foundation
http://www.osgeo.org/
http://www.grassbook.org/
Markus,
2008/3/20, Markus Neteler <neteler@osgeo.org>:
in libgis I see
I need list of accessible mapsets for wxGUI welcome screen (currently
'g.mapsets -l' is used which prints all available mapsets). Modifying
g.mapsets module to print only accessible mapsets would be pretty easy
(aka new flag), BTW how TCL/TK checks if mapsets is accessible (I see
that those mapsets are hidden in welcome screen)?
Martin
In TclTk it's done simply by listing all directories owned by user -
lib/init/gis_set.tcl:
foreach i [lsort [glob -directory [pwd] *]] {
if {[file isdirectory $i] && [file owned $i] } {
$mapList insert end [file tail $i]
Maris.
2008/3/20, Martin Landa <landa.martin@gmail.com>:
Markus,
Martin
Martin Landa wrote:
At the C level, G__mapset_permissions() and G__mapset_permissions2()
determines whether or not a specific mapset can be used as the current
mapset (i.e. it's a directory, and you own it).
AFAIK, there isn't a user command to determine this. If it's useful,
it really belongs in g.mapset rather than g.mapsets, as the former
deals with the current mapset (used for output) while the latter deals
with the mapsets used for input.
2008/3/20, Glynn Clements <glynn@gclements.plus.com>:
I think it would be useful, at least for creating list of mapsets in
GUI start-up screen. Currently is used 'g.mapsets -l' which prints all
mapsets in the location. I don't fully understand here, why g.mapsets
is not good place for that.
g.mapsets -l -> prints *all* mapsets
g.mapsets -a -> print only *accessible* mapset
At least this would be useful for GUI start-up screen (to disable not
accessible mapsets).
Martin
Markus:
in libgis I see
it would be nice to have inaccessible mapsets listed in the GUI mapset
selection box, but greyed out.
away until next week,
Hamish
      ____________________________________________________________________________________
Be a better friend, newshound, and
know-it-all with Yahoo! Mobile. Try it now. http://mobile.yahoo.com/;_ylt=Ahu06i62sR8HDtDypao8Wcj9tAcJ
2008/3/20, Hamish <hamish_b@yahoo.com>:
Markus:
> in libgis I see
yes, that's what I would like to implement, combination of `g.mapsets
-l` and `g.mapsets -a` could be a solution.
Martin
"g.mapsets -l" displays a list of mapsets which are suitable for use
as values in g.mapsets' mapset= and addmapset= options.
You are essentially asking about mapsets which are suitable for use as
values in the mapset= option of g.mapset[1]. The logical place for
such an option is in g.mapset.
[1] init.sh/init.bat have their own built-in clone of g.mapset. It
would be worth looking into whether they can be changed to use
g.mapset instead.
There is a great deal of asymmetry between output and input; the
current mapset and the mapset search path are really very different
entities. g.mapset deals exclusively with the former, g.mapsets deals
exclusively with the latter.
And the option which you're proposing is related to the former.
"accessible" is the wrong word here. You can "access" any mapset for
which you have read permission.
the attached patch adds to g.mapset module new flag '-l' (print
available mapsets with write permission). It requires dummy value for
mapset, e.g.
g.mapset -l map=dummy
same story like `r.in.gdal -f` and others. It would be reasonable to
introduce new attribute in option/flag structure, something like
'suppress_required'. The value could be global (YES/NO), to suppress
all required flags/options or better list of option/flags (e.g. their
keys) which are required and will be suppressed by the given
flag/option.
Regards, Martin
2008/3/21, Glynn Clements <glynn@gclements.plus.com>:
g.mapset instead.
(attachments)
g-mapset-l.diff (1.33 KB)
mapset, e.g.
I've committed the patch, but changed mapset_opt->required to NO.
flag/option.
Initially, it should just be global, i.e. the switch can be used on
its own, with no other options required.
Anything more involved than that should be part of an overall redesign
of "required" options, e.g. option groups.
However, I'm not sure that even the simplest version should go into
6.3, the critical nature of the parser.
2008/3/24, Glynn Clements <glynn@gclements.plus.com>:
thanks, small issue here -- the '-l' flag ignores gisdbase= and
location= parameters, it always prints list of mapsets for the
*current* location. The attached patch should fix it. If you have no
objections I will applied in trunk.
Martin
(attachments)
g_available_mapsets2.diff (3.01 KB)
I'm not sure that a separate function with gisdbase/location arguments
is necessary. It is sufficient for g.mapset to just change those
settings with G__setenv().
2008/3/25, Glynn Clements <glynn@gclements.plus.com>:
applied in trunk
http://trac.osgeo.org/grass/changeset/30725
Martin
