`g.mapset` has currently several options to set/add/remove mapsets
from the search path
mapset Name(s) of existing mapset(s)
addmapset Name(s) of existing mapset(s) to add to search path
removemapset Name(s) of existing mapset(s) to remove from search path
I would suggest to change syntax of `g.mapset` to allow only one
operation when launching module.
operation=add,set,remove Operation to perform
Make sense to you?
Martin
Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
2012/4/12 Martin Landa <landa.martin@gmail.com>:
mapset Name\(s\) of existing mapset\(s\)
addmapset Name\(s\) of existing mapset\(s\) to add to search path
Make sense to you?
yes, maybe the default operation should be add
Martin
ciao
Luca
http://gis.cri.fmach.it/delucchi/
www.lucadelu.org
BTW, these options exist for g.mapsets, not for g.mapset.
Make sense to you?
+1
Markus M
2012/4/12 Markus Metz <markus.metz.giswork@googlemail.com>:
sure, sorry for typo. Martin
On Thu, Apr 12, 2012 at 6:02 PM, Martin Landa <landa.martin@gmail.com> wrote:
Make sense to you?
+1 to change g.mapsets
2012/4/14 Markus Neteler <neteler@osgeo.org>:
Make sense to you?
done in r51471.
Martin
