[GRASS-dev] g.mlist: exclude parameter wish
would it be complicated to add an "exclude_pattern" parameter to
g.mlist/g.mremove?
Example: I want to select only the gpcp_1dd_p1d_*_count maps but not the monthly
counts:
g.mlist type=rast patt="gpcp_1dd_p1d_*_count"
gpcp_1dd_p1d_1997_2007_month04_10_count
gpcp_1dd_p1d_1997_count
gpcp_1dd_p1d_1997_month04_10_count
gpcp_1dd_p1d_1998_count
gpcp_1dd_p1d_1998_month04_10_count
gpcp_1dd_p1d_1999_count
gpcp_1dd_p1d_1999_month04_10_count
gpcp_1dd_p1d_2000_count
gpcp_1dd_p1d_2000_month04_10_count
gpcp_1dd_p1d_2001_count
gpcp_1dd_p1d_2001_month04_10_count
gpcp_1dd_p1d_2002_count
gpcp_1dd_p1d_2002_month04_10_count
gpcp_1dd_p1d_2003_count
gpcp_1dd_p1d_2003_month04_10_count
gpcp_1dd_p1d_2004_count
gpcp_1dd_p1d_2004_month04_10_count
gpcp_1dd_p1d_2005_count
gpcp_1dd_p1d_2005_month04_10_count
gpcp_1dd_p1d_2006_count
gpcp_1dd_p1d_2006_month04_10_count
gpcp_1dd_p1d_2007_count
gpcp_1dd_p1d_2007_month04_10_count
Wish (ideal world):
g.mlist type=rast patt="gpcp_1dd_p1d_*_count" exclude="month"
I know that -r and -e are available but I failed to write an exclusion regex.
And often just simple patterns are to be suppressed in the selection.
Hi Markus
On Wed, 19 Nov 2008, Markus Neteler wrote:
g.mlist/g.mremove?
counts:
What about
g.mlist type=rast patt="gpcp_1dd_p1d_???_count"
I think that should work with a shell script version of g.mlist anyway, as ? characters can be used to represent single characters in wildcard patterns passed to the ls command.
Paul
On Wed, Nov 19, 2008 at 10:51 AM, Paul Kelly
<paul-grass@stjohnspoint.co.uk> wrote:
Hi Markus
g.mlist/g.mremove?
monthly
counts:
What about
bingo :slight_smile:
This works, resolved for today.
exclude="month"
an exclusion regex.
selection.
no idea about the C version, but with the shell script version it would
be roughly like
if [ -n "$GIS_OPT_EXCLUDE" ] ; then
  EXCLD_STR="| grep -v $GIS_OPT_EXCLUDE"
else
  EXCLD_STR=""
fi
g.list * ... | ... $EXCLD_STR
do you now use g.mlist | grep -v 'expr' ?
Hamish
On Wed, Nov 19, 2008 at 11:12 AM, Hamish <hamish_b@yahoo.com> wrote:
exclude="month"
an exclusion regex.
selection.
be roughly like
else
EXCLD_STR=""
fi
Yes - but I dunno how to implement that in C.
g.mlist type=rast patt="gpcp_1dd_p1d_*_count" | grep -v month | tr
'\n' ',' | sed 's+,$++g
but that's rather funky for daily usage.
[for today, Paul's trick helped but the problem will return]
Markus,
We could add the exclude option, but I'm not so sure if we really need it.
You can solve your problem by using a more specific wildcard if Paul's
trick doesn't work.
pat="gpcp_1dd_p1d_[0-9][0-9][0-9][0-9]_count"
It's a little lengthy, but it works. Any better examples where we might
want the exclude option?
Huidae
>> exclude="month"
>> an exclusion regex.
>> selection.
> be roughly like
> else
> EXCLD_STR=""
> fi
grass-dev mailing list
grass-dev@lists.osgeo.org
trick doesn't work.
Also, you can always use 'g.mlist ... | grep -v ...'.
OTOH, adding e.g. G_set_ls_exclude_filter() wouldn't be much work.
Although it's theoretically possible to complement or "subtract"
regular expressions, in practice it's rather ugly, i.e. the result is
often far more complex than the original(s). And it isn't possible to
complement glob patterns.
While we're on the subject, I'm wondering if it would be worthwhile
using glob() where it's available (i.e. everywhere except Windows),
instead constructing an equivalent[1] regexp.
[1] There are a number of differences between g.mlist's glob patterns
and glob(), e.g. it doesn't support complemented ranges, it interprets
metacharacters within ranges, etc.
> trick doesn't work.
I've now added G_set_ls_exclude_filter() and an exclude= option to
g.list.
On Thu, Nov 20, 2008 at 4:22 PM, Glynn Clements
trick doesn't work.
Imagine thousands of similar map names (derivatives of time series
elaborations), then wildcards won't suffice.
In a script it needs to be:
LIST=`g.mlist type=rast patt=... | grep -v ... | tr '\n' ',' | sed 's+,$++g`
which is already more complicated (not for me but for xx% of
the users).
This would be pretty convenient.
I have no idea, sorry... so cannot comment on "glob".
