[GRASS-dev] G_OPT_R_MAP vs G_OPT_R_INPUT
What is the difference between G_OPT_R_MAP and G_OPT_R_INPUT? Which and why should I prefer for my script(s)?
Is there a step-by-step run-through of all options for composing header definitions?
Nikos
definitions?
Nikos
grass-dev mailing list
grass-dev@.osgeo
see
http://grass.osgeo.org/programming7/gis_8h.html#a5521b5269c52afe64e5051348b08fc69
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/G-OPT-R-MAP-vs-G-OPT-R-INPUT-tp5173026p5173030.html
Sent from the Grass - Dev mailing list archive at Nabble.com.
definitions?
Nikos
grass-dev@.osgeo
see
But that table doesn't really answer the question,
does it? For both "G_OPT_R_INPUT" and "G_OPT_R_MAP"
it lists "old input raster map". AFAIU, "G_OPT_R_MAP"
is for modules that use only one input raster map.
In those cases, the corresponding input option should
be named "map=". "G_OPT_R_INPUT" would then be for
modules that have either several raster map inputs or
raster and vector maps as inputs. The corresponding
input options would then be called "raster=" and
"vector=" in case of exactly one raster and one vector
input map. Further special cases are covered by
"G_OPT_R_BASE", "G_OPT_R_ELEV", etc.: They all exist
for semantical purposes. All of them stand for raster
input maps.
Ben
best regards
Helmut
grass-dev@lists.osgeo.org
Dr. Benjamin Ducke
{*} Geospatial Consultant
{*} GIS Developer
Spatial technology for the masses, not the classes:
experience free and open source GIS at http://gvsigce.org
definitions?
Nikos
grass-dev@.osgeo
see
input maps.
I've always understood the difference between MAP and INPUT as
- MAP: used for modules which treat a map, but do not have input+output logic (e.g. r.category, r.colors, etc)
- INPUT: used for modules that have input + output logic (r.cost, r.mfilter, etc)
The difference between one or multiple inputs is covered by
G_OPT_R_INPUT vs G_OPT_R_INPUTS.
Moritz
definitions?
see
Yes, I was skimming through it before.
be named "map=".
And what is the (semantic) purpose of G_OPT_R_MAPS (MAPS vs MAP) then?
And, likewise, what about G_OPT_R_INPUTS?
The corresponding input options would then be called "raster="
and "vector=" in case of exactly one raster and one vector
input maps.
Nikos
definitions?
see
input maps.
r.mfilter, etc)
So, then we have:
G_OPT_R_INPUT -> single raster map for modules featuring output(s)
G_OPT_R_INPUTS -> multiple input raster maps for modules feat. output(s)
G_OPT_R_MAP -> single raster map for modules operating on "this" map
G_OPT_R_MAPS -> multiple raster maps for modules operating on "these" maps
Right?
Nikos
Which and
header
definitions?
see
input maps.
r.mfilter, etc)
So, then we have:
output(s)
maps
Right?
At least that is how I've always interpreted it. You'd have to check individual modules if this is actually how things have been applied...
Moritz
Which and
header
definitions?
see
input maps.
r.mfilter, etc)
So, then we have:
output(s)
maps
Right?
Already did. Some counts for the scripts inside /grass70/dist.x86_64-unknown-linux-gnu/scripts
G_OPT_R_MAP: x5
G_OPT_R_MAPS: x1
G_OPT_R_INPUT: x34
G_OPT_R_INPUTS: x8
