Given the following
#%option
#% key: sea
#% key_desc: degrees
#% type: double
#% description: Aquisition's Sun Elevation Angle
#% options: 0.0 - 90.0
#% guisection: Metadata
#% required: yes
#%end
import grass.script as grass
def main()
sea = options['sea']
if __name__ == "__main__":
options, flags = grass.parser()
sys.exit(main())
Isn't supposed that sea is returned as a float? Is it really necessary to do
sea = float(options['sea'])
Grazie, Nikos
neteler
November 15, 2014, 4:24pm
2
On Sat, Nov 15, 2014 at 4:19 PM, Nikos Alexandris
<nik@nikosalexandris.net> wrote:
Given the following
#%option
#% key: sea
#% type: double
... this defines what type is *accepted* as input.
#% required: yes
#%end
def main()
sys.exit(main())
No, above is the definition for the accepted input type.
Yes.
Nikos Alexandris
Given the following..
#%option
#% key: sea
#% type: double
#% required: yes
#%end
def main()
sys.exit(main())
Yes.
Grazie Markus.
Is it too much work to make this automatic? I am trying to think why should a user/scripter want something else than the type that the parameter (in CLI or wx-GUI) requests?
Nikos
Nikos
