Hamish wrote:
also I noticed there were some extra ^M chars in the *.dat files which
shouldn't be there,
I wonder if those standard schemes should be hardcoded in a *.h file,
with an option to chose one of them by name or "custom" with an optional
and add/rename a new option called rules= to load the custom file?
then less work to specify path to the *.dat file...
also, what should the two sand and clay maps look like? percent/fraction
makeup of soil for each cell?
Hamish
