[GRASS-dev] g.parser: gisprompt: color-option ?
hi,
is there a way to configure a shell-script using
#% gisprompt
to encourage the g.parser module to provide a color selection window (like the ones in d.vect for color/bcolor) ?
The straightforward approach
#% gisprompt old,color,color
does not work.
Peter
Dr. Peter Löwe
Diplom-Geograph
<loewe@geomancers.net>
<peter.loewe@gmx.de>
Der GMX SmartSurfer hilft bis zu 70% Ihrer Onlinekosten zu sparen!
Ideal für Modem und ISDN: http://www.gmx.net/de/go/smartsurfer
#% gisprompt
does not work.
Use:
  #% gisprompt: color,grass,color
That's what d.vect uses; the GUI only requires that the string begins
with "color," to display a colour selector dialog.
