[GRASS-dev] g.region: a possible extension to support multiple zoom= and mode=intersect
  As `zoom=' somewhat mimics `rast=', wouldn't it be natural to
  extend `zoom=' to allow multiple rasters?
  Allowing multiple rasters for `zoom=' may make one wonder about
  some further extensions. Firstly, wouldn't it be useful to
  allow both `rast=' and `zoom=' be specified at the same time to
  calculate the least region covering both the `rast=' and `zoom='
  rasters (with the usual `rast=' and `zoom=' behaviour still
  followed)? What about adding `vect=' and `region=' as well?
  Secondly, the above extensions make it easy to compute set union
  (or rather its boundary box) of the regions (specified as named
  regions, rasters or vectors), but it seems to be useful to allow
  one to calculate set intersection as well. Hence,
  `mode=intersect' as a counterpart to the default `mode=union'
  (or `mode=traditional'?)
  Please note that the last change is somewhat disturbing to the
  existing code, since the result of the intersection may well be
  an empty region, while AFAIK there's no conception of empty
  region in GRASS currently.
Ivan Shmakov pisze:
Talking about g.region vect= - I'd find it very usefull if it honored the 3d vector coordinates too. Currently one has to set top and bottom manually in accordance with his 3d vector.
Maciek
"MS" == Maciej Sieczka <tutey@o2.pl> writes:
  Do you mean something like the following?
--- general/g.region/main.c.~2~ 2008-04-02 01:11:59.000000000 +0700
+++ general/g.region/main.c 2008-04-02 11:15:40.000000000 +0700
@@ -515,6 +515,8 @@
       map_window.south = box.S;
       map_window.west = box.W;
       map_window.east = box.E;
+ map_window.top = box.T;
+ map_window.bottom = box.B;
       if (!first)
@@ -531,6 +533,10 @@
           window.east : map_window.east;
         window.west = (window.west < map_window.west) ?
           window.west : map_window.west;
+ if (map_window.top > window.top)
+ window.top = map_window.top;
+ if (map_window.bottom < window.bottom)
+ window.bottom = map_window.bottom;
       if(window.north == window.south)
@@ -543,6 +549,12 @@
             window.west = window.west - 0.5 * temp_window.ew_res;
             window.east = window.east + 0.5 * temp_window.ew_res;
+ if (window.top == window.bottom) {
+ window.bottom = (window.bottom
+ - 0.5 * temp_window.tb_res);
+ window.top = (window.top
+ + 0.5 * temp_window.tb_res);
       if(flag.res_set->answer)
           G_align_window (&window, &temp_window);
Ivan Shmakov <ivan@theory.asu.ru> writes:
> @@ -515,6 +515,8 @@
> if (!first)
  BTW, I'm not familiar with either 3D-vectors or 3D-rasters, so
  could someone with a better knowledge of them test this (and
  possibly the other [1]) patch? Or should I put it to Trac?
[1] http://permalink.gmane.org/gmane.comp.gis.grass.devel/26185
> BTW, I'm not familiar with either 3D-vectors or 3D-rasters, so could
> someone with a better knowledge of them test this (and possibly the
  I have opened a ticket [1] for the issue.
[1] http://trac.osgeo.org/grass/ticket/121
