Dear devs,
when I'm using g.remove (gui), If I select to remove a raster map the
menu (name) does not work, instead if I select vector works without
problems...
I'm using grass7 (r64189), do you have the same problem?
Best regards
Pietro
Dear devs,
problems...
Best regards
Pietro
2015-01-15 10:48 GMT+01:00 Pietro <peter.zamb@gmail.com>:
problems...
the GUI dialog of this module doesn't work for me at all. I am still
getting "No selectable element" regardless type I check.
Martin
Martin Landa
http://geo.fsv.cvut.cz/gwiki/Landa
http://gismentors.eu/mentors/landa
2015-01-15 11:13 GMT+01:00 Martin Landa <landa.martin@gmail.com>:
please fill the ticket, it's blocker I would say. Martin
Martin Landa
On Thu, Jan 15, 2015 at 5:13 AM, Martin Landa <landa.martin@gmail.com>
> getting "No selectable element" regardless type I check.please fill the ticket, it's blocker I would say. Martin
honestly, that was a bad idea to backport
http://trac.osgeo.org/grass/changeset/64105
fixed in r64190,1
Anna
Martin Landa
grass-dev mailing list
grass-dev@lists.osgeo.org
2015-01-15 14:03 GMT+01:00 Anna Petrášová <kratochanna@gmail.com>:
fixed in r64190,1
thanks for the fix. Martin
Martin Landa
2015-01-15 22:26 GMT+01:00 Martin Landa <landa.martin@gmail.com>:
fixed in r64190,1
what exactly it should fix? I tried g.remove GUI again (relbr70) and
there is still "No selectable element" regardless selected type...
Martin
Martin Landa
On Thu, Jan 15, 2015 at 6:09 PM, Martin Landa <landa.martin@gmail.com>
>> fixed in r64190,1
> thanks for the fix. Martinwhat exactly it should fix? I tried g.remove GUI again (relbr70) and
Interesting, before it was broken with both wxPython 2.8 and 3, now only
with wxPython 3. I will look at it.
Martin
Martin Landa
On Thu, Jan 15, 2015 at 8:34 PM, Anna Petrášová <kratochanna@gmail.com>
wrote:2015-01-15 22:26 GMT+01:00 Martin Landa <landa.martin@gmail.com>:
>> fixed in r64190,1
there is still "No selectable element" regardless selected type...Interesting, before it was broken with both wxPython 2.8 and 3, now only
ok, should be fixed in r64210. The Select widget consist of comboctrl and
textctrl and the source of events has apparently changed. I already fixed a
couple of those but I am sure there are still a lot of bugs.
Martin
Martin Landa
On Fri, Jan 16, 2015 at 3:24 AM, Anna Petrášová <kratochanna@gmail.com> wrote:
Thank you so much Anna for the quick fix!
Pietro
2015-01-16 3:24 GMT+01:00 Anna Petrášová <kratochanna@gmail.com>:
I have tested with both wxPython 2.8 and 3.0 and it seems to work.
Thanks for quick fix! Please could you backport it?
Martin
Martin Landa
On Fri, Jan 16, 2015 at 3:52 AM, Martin Landa <landa.martin@gmail.com>
wrote:
fixed a
> couple of those but I am sure there are still a lot of bugs.I have tested with both wxPython 2.8 and 3.0 and it seems to work.
Done in r64229.
Martin
Martin Landa
2015-01-17 16:16 GMT+01:00 Anna Petrášová <kratochanna@gmail.com>:
Thanks for quick fix! Please could you backport it?Done in r64229.
Thanks! Martin
Martin Landa
