Hello,
I you use the GUI of g.remove and select some raster files it adds the @mapset
as well which causes an error when executing this command:
copy/paste of GUI command:
g.remove rast=dispersalmap_missing_2@march07
Removing raster <dispersalmap_missing_2@march07>
Illegal filename. Character <@> not allowed.
raster: couldn't be removed
header: couldn't be removed
category: couldn't be removed
color: couldn't be removed
history: couldn't be removed
misc: couldn't be removed
fcell: couldn't be removed
g3dcell: couldn't be removed
colr2/march07: couldn't be removed
<dispersalmap_missing_2@march07> nothing removed
Martin
When did you last update? I think that I fixed this one on the 20th.
> @mapset as well which causes an error when executing this command:
I did a cvs update again and compiled it again by hand
(rm -rf /usr/local/grass6.... ), make distclean, ./configure, make, make
install now g.remove works but the g.copy problem remains.
thanks, Martin
