g.setproj doesn't let you run it from a XY location.
is that really necessary? it makes it hard to import unprojected imagery,
reset to known bounds with r.region, and then change into a lat/lon
location. note in that workflow the raster's cellhd/ file must be hacked
to be proj: 3.
to be proj: 3.
You could probably merge the "case 0" with PROJECTION_OTHER, so it
prompts for the projection.
