> g.setproj doesn't let you run it from a XY location.
> is that really necessary?
> it makes it hard to import unprojected imagery, reset to
> known bounds with r.region, and then change into a lat/lon
> location. note in that workflow the raster's cellhd/
> file must be hacked to be proj: 3.
Glynn wrote:
You could probably merge the "case 0" with
PROJECTION_OTHER, so it prompts for the projection.
I don't think it's a problem to technically do it, I'm just
trying to figure out if there's any good reason for it being
the way it is.
I have worked around the long-standing problem of "illegal
latitude for north" by adding a new -l flag to r.in.gdal which
will reset the image bounds to within 90N,S. With lots of
warnings to run r.region of course. I figure coords based on
pixels are arbitrary as well, so it is not any more wrong to do
that, and much better than removing the libgis restriction.
the way it is.
To hazard a guess: originally all the projection information for a GRASS location was contained within the WIND file. In the very beginning this would have just been UTM zone details, then it was extended to handle latitude/longitude, and then extended further to handle State Plane. When support for using PROJ.4 for reprojections was hacked in (AFAIK from a non-CERL source, and originally just for v.proj), it couldn't use the projection information in the GRASS WIND files and instead required new-style PROJ_INFO and PROJ_UNITS files to be added to the location, augmenting and partially duplicating the information in the WIND file. I suspect the original g.setproj might not have altered the WIND/DEFAULT_WIND files at all, but simply created PROJ_INFO and PROJ_UNITS files. So the idea was not that g.setproj could make an unprojected location projected, but just that it would augment the existing projection information with projection information in an extended
format. Thus it made no sense to run it on an XY location as there was no existing projection to be augmented - and indeed if the original g.setproj did not edit WIND files then it would have been impossible for it to change the projection of a location as it can do now.
That's all just conjecture based on clues I've picked up in the projection code over the years, but I suppose it might be possible to prove or disprove it by digging into some old GRASS sources!
The issue of removing this restriction has come up loads of times but I never liked the idea of doing it in case I broke something else, as the g.setproj code is such a mess. But Glynn's suggestion sounds sensible so I would say go for it in 6.5/7.0 and see if anything breaks.
