Dear devs,
while extending some g3d modules i noticed that the resampling function
(nearest neighbor) and the window structure is not set when a new g3d map
is created (G3d_openCellNew()). Only G3d_openCellOld() sets those values.
Was there a specific reason to not implement this in G3d_openCellNew()?
I do need this functionality!
Without setting the resampling function and the window of the new map,
i do not have access to values i have already written with G3d_putValue().
G3d_getValue() will give only null values or will crash.
I have added a diff of the changes i want to make to lib/g3d/g3dopen.c.
What do you think?
Best regards
Soeren
cvs server: Diffing .
Index: g3dopen.c
RCS file: /home/grass/grassrepository/grass6/lib/g3d/g3dopen.c,v
retrieving revision 2.4
diff -u -r2.4 g3dopen.c
--- g3dopen.c 6 May 2006 22:50:17 -0000 2.4
+++ g3dopen.c 5 Aug 2006 13:56:52 -0000
@@ -320,6 +320,11 @@
return (void *) NULL;
+ /*Set the map window to the map region */
+ G3d_regionCopy (&(map->window), region);
+ /*Set the resampling function to nearest neighbor for data access */
+ G3d_getNearestNeighborFunPtr (&(map->resampleFun));
G3d_maskOff (map);
return (void *) map;
