[GRASS-dev] G7.0.svn: g.remove segfault
to my surprise I managed to generate a segfault using g.remove:
GRASS 7.0.1svn (eu_laea):~ > g.list raster
pattern="modis_lst1km*.spring_warming"
modis_lst1km2003.spring_warming
modis_lst1km2004.spring_warming
modis_lst1km2005.spring_warming
modis_lst1km2006.spring_warming
modis_lst1km2007.spring_warming
modis_lst1km2008.spring_warming
modis_lst1km2009.spring_warming
modis_lst1km2010.spring_warming
modis_lst1km2011.spring_warming
modis_lst1km2012.spring_warming
modis_lst1km2013.spring_warming
modis_lst1km2014.spring_warming
GRASS 7.0.1svn (eu_laea):~ > g.remove raster
pattern="modis_lst1km*.spring_warming" -f
Removing raster <modis_lst1km2003.spring_warming>
*** buffer overflow detected ***: g.remove terminated
======= Backtrace: =========
/lib64/libc.so.6(__fortify_fail+0x37)[0x7f4548c54a07]
/lib64/libc.so.6(+0x10bbd0)[0x7f4548c52bd0]
/lib64/libc.so.6(+0x10b0f9)[0x7f4548c520f9]
/lib64/libc.so.6(_IO_default_xsputn+0xbc)[0x7f4548bc04bc]
/lib64/libc.so.6(_IO_vfprintf+0x3939)[0x7f4548b91f49]
/lib64/libc.so.6(__vsprintf_chk+0x88)[0x7f4548c52188]
/lib64/libc.so.6(__sprintf_chk+0x7d)[0x7f4548c520dd]
/usr/local/grass-7.0.1svn/lib/libgrass_manage.7.0.1svn.so(M_do_remove+0x3bb)[0x7f4549671cfb]
g.remove(main+0x76a)[0x4022be]
/lib64/libc.so.6(__libc_start_main+0xf5)[0x7f4548b68af5]
g.remove[0x4015c9]
======= Memory map: ========
00400000-00403000 r-xp 00000000 fd:00 275018341
  /usr/local/grass-7.0.1svn/bin/g.remove
00602000-00603000 r--p 00002000 fd:00 275018341
(gdb) bt
#0 0x00007ffff70e35e9 in raise () from /lib64/libc.so.6
#1 0x00007ffff70e4cf8 in abort () from /lib64/libc.so.6
#2 0x00007ffff7123dd7 in __libc_message () from /lib64/libc.so.6
#3 0x00007ffff71bba07 in __fortify_fail () from /lib64/libc.so.6
#4 0x00007ffff71b9bd0 in __chk_fail () from /lib64/libc.so.6
#5 0x00007ffff71b90f9 in _IO_str_chk_overflow () from /lib64/libc.so.6
#6 0x00007ffff71274bc in __GI__IO_default_xsputn () from /lib64/libc.so.6
#7 0x00007ffff70f8f49 in vfprintf () from /lib64/libc.so.6
#8 0x00007ffff71b9188 in __vsprintf_chk () from /lib64/libc.so.6
#9 0x00007ffff71b90dd in __sprintf_chk () from /lib64/libc.so.6
#10 0x00007ffff7bd8cfb in sprintf (__fmt=0x7ffff7bd95e6 "colr2/%s",
    __s=0x7fffffffc360
"colr2/modis_lst_reconstructed_europe_cooling_warmj\275\367\377\177")
    at /usr/include/bits/stdio2.h:33
#11 M_do_remove (n=n@entry=0, old=0x655f00
"modis_lst1km2005.spring_warming") at do_remove.c:102
#12 0x00000000004022be in main (argc=<optimized out>, argv=<optimized
out>) at main.c:250
g.version -r
GRASS 7.0.1svn (2015)
libgis Revision: 64733
uname -a
Linux giscluster.intra.ismaa.it 3.10.0-229.1.2.el7.x86_64 #1 SMP Thu
Mar 26 09:10:25 CDT 2015 x86_64 x86_64 x86_64 GNU/Linux
I'm travelling now, so no chance to test myself at time.
It seems to stumble over the color2 file.
On Wed, Jun 24, 2015 at 9:06 AM, Markus Neteler <neteler@osgeo.org> wrote:
please disregard. Apparently a system update triggered this (no idea how).
"make distclean" helped.
sorry for the noise
> Hi,
Well, you are not the only one with the problem:
https://lists.osgeo.org/pipermail/grass-dev/2015-May/075083.html
I will have to try distclean, although I think I tried it several times
before.
sorry for the noise
grass-dev mailing list
grass-dev@lists.osgeo.org
wrote:
> Hi,
before.
I'm getting the same issues again. Now I actually see a buffer overflow:
/lib/x86_64-linux-gnu/libc.so.6(+0x7338f)[0x7fc697b2b38f]
/lib/x86_64-linux-gnu/libc.so.6(__fortify_fail+0x5c)[0x7fc697bc2c9c]
/lib/x86_64-linux-gnu/libc.so.6(+0x109b60)[0x7fc697bc1b60]
/lib/x86_64-linux-gnu/libc.so.6(+0x109069)[0x7fc697bc1069]
/lib/x86_64-linux-gnu/libc.so.6(_IO_default_xsputn+0xbc)[0x7fc697b3370c]
/lib/x86_64-linux-gnu/libc.so.6(_IO_vfprintf+0x26b0)[0x7fc697b043a0]
/lib/x86_64-linux-gnu/libc.so.6(__vsprintf_chk+0x84)[0x7fc697bc10f4]
/lib/x86_64-linux-gnu/libc.so.6(__sprintf_chk+0x7d)[0x7fc697bc104d]
/home/vpetras/dev/grass/trunk/dist.x86_64-unknown-linux-gnu/lib/
libgrass_manage.7.1.svn.so(M_do_remove+0
x2e8)[0x7fc6982e9148]
g.remove(main+0x68d)[0x401c5d]
/lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xf5)[0x7fc697ad9ec5]
g.remove[0x401e3e]
00400000-00403000 r-xp 00000000 08:11 16127189
ist.x86_64-unknown-linux-gnu/bin/g.remove
00602000-00603000 r--p 00002000 08:11 16127189
00603000-00604000 rw-p 00003000 08:11 16127189
It fails with a lot of tests but with many other it works. I'm not sure if
all errors are stack overflow but I could catch all output the a fine next
time.
Vaclav
I can not repeat the issue with current trunk on ~AMD64 Gentoo.
Please provide locale information; run g.remove under valgrind to see
the source of memory corruption.
Māris.
2015-06-25 3:47 GMT+03:00 Vaclav Petras <wenzeslaus@gmail.com>:
wrote:
> Hi,
how).
before.
/home/vpetras/dev/grass/trunk/dist.x86_64-unknown-linux-gnu/lib/libgrass_manage.7.1.svn.so(M_do_remove+0
g.remove[0x401e3e]
time.
Vaclav
That's the hard part. I cannot run valgrind easily. I'm not getting the
error when I execute it manually (at least not often enough). It is
happening only with some part of tests for me. As I've written before, I
originally haven't reported it at all because I'm getting with one copy of
GRASS but not with the other on the same machine without being able to find
any difference in between them. (Fortunately the copy which works is the
one running the automated tests.) Only after Soeren and now Markus reported
the same, I started to lean towards opinion that it is not a local issue.
As for valgrind, that's unfortunately a feature request for gunittest.
Which is even more advanced then I expected because valgrind is not need
for the tested module but just for a helper one, anyway, the testing
framework should allow that.
I'm not sure if Soeren can repeat it in more direct way.
Māris.
>>> wrote:
>>> > Hi,
>>> how).
>> before.
> g.remove[0x401e3e]
if
next
> time.
> Vaclav
here a traceback of a g.remove segfault that happens while testing
temporal modules:
http://pastebin.com/LDVKgEed
Seems to be in M_do_remove calling some sort of sprintf?? Maybe line
102, since the colr2 buffer is only 50 chars in length ... however,
sprintf() function shouldn't be used at all.
Best regards
Soeren
2015-06-26 16:11 GMT+02:00 Vaclav Petras <wenzeslaus@gmail.com>:
any difference in between them. (Fortunately the copy which works is the one
running the automated tests.) Only after Soeren and now Markus reported the
As for valgrind, that's unfortunately a feature request for gunittest. Which
is even more advanced then I expected because valgrind is not need for the
tested module but just for a helper one, anyway, the testing framework
should allow that.
Māris.
>>> wrote:
>>> > Hi,
>>> how).
>> before.
> g.remove[0x401e3e]
> if
> next
> time.
> Vaclav
may i suggest a patch to solve this issue?
http://pastebin.com/D8yautBh
Best regards
Soeren
2015-06-26 20:27 GMT+02:00 Sören Gebbert <soerengebbert@googlemail.com>:
temporal modules:
Best regards
Soeren
should allow that.
Māris.
>>> wrote:
>>> > Hi,
>>> how).
>> before.
> g.remove[0x401e3e]
> if
> next
> time.
> Vaclav
On Fri, Jun 26, 2015 at 2:37 PM, Sören Gebbert <soerengebbert@googlemail.com
wrote:
Sure!
I'm not sure if I can judge the path. However, sprintf is used a lot in
GRASS, so I'm not sure if we can just replace it with other function
without understanding what is the issue (at least I don't understand).
As for the magic number there, there is G_PATH_MAX or something, perhaps
that would be more appropriate.
If the issue is length of the path, then I understand why it was happening
for the tests - they use long Mapset names and possibly also map long map
names.
Best regards
Soeren
> Hi,
> temporal modules:
> Best regards
> Soeren
of
find
the one
the
Which
the
>> should allow that.
>>> Māris.
>>> >>> wrote:
>>> >>> > Hi,
idea
>>> >>> how).
times
>>> >> before.
overflow:
>>> > g.remove[0x401e3e]
sure
>>> > if
>>> > next
>>> > time.
>>> > Vaclav
>>> > _______________________________________________
2015-06-26 21:03 GMT+02:00 Vaclav Petras <wenzeslaus@gmail.com>:
<soerengebbert@googlemail.com> wrote:
Sure!
Ok, i will commit the patch.
GRASS, so I'm not sure if we can just replace it with other function without
All sprintf calls in GRASS should be replaced by G_snprintf() because
sprintf is by design unsafe and the result of many buffer overflows
and eventually exploits. sprintf does not check the size of the target
buffer but G_snprintf does (if used correctly).
Yes, it would.
names.
The length is one issue, but sprintf causes the segfault by writing
more than 50 chars if G_mapset() returns long mapset names as in case
of the temporary generated test mapsets.
Best regards
Soeren
Best regards
Soeren
> Hi,
> temporal modules:
> Best regards
> Soeren
>> I
>> of
>> find
>> the one
>> the
>> Which
>> the
>> should allow that.
>>> Māris.
>>> >>> <neteler@osgeo.org>
>>> >>> wrote:
>>> >>> > Hi,
>>> >>> idea
>>> >>> how).
>>> >> times
>>> >> before.
>>> > overflow:
>>> > g.remove[0x401e3e]
>>> > sure
>>> > if
>>> > fine
>>> > next
>>> > time.
>>> > Vaclav
On Fri, Jun 26, 2015 at 3:54 PM, Sören Gebbert <soerengebbert@googlemail.com
> Sure!
without
Yes, it would.
When I said "G_PATH_MAX or something" I meant that you should check me not
commit without even compiling the code :slight_smile: Fixed in r65525 after
compilation and tests*.
Vaclav
* although there are no tests testing colr2
https://trac.osgeo.org/grass/changeset/65524
https://trac.osgeo.org/grass/changeset/65525
