[GRASS-dev] G7 blockers call
we are slowly moving towards GRASS 7 release. Recently 3rd beta has
been released. It's importnant to know what is still missing before we
start RC stage. So please report ASAP issues which you feel that they
need to be solved before GRASS 7 will be released (especially API
changes, renaming modules, parameters, everything which is impossible
to change later because of backward compatibility).
Please report this issues as 'blockers'. Other notes can be collected
on trac wiki page [1].
Thanks for collaboration! Martin
[1] http://trac.osgeo.org/grass/wiki/Grass7Planning
Martin Landa * http://geo.fsv.cvut.cz/gwiki/Landa
Martin,
our semester has just started and we have students downloading and installing GRASS7.0.0RC3.
So far I had two students reporting the problem with MSVCR.71.dll missing - I have added the link to the
WinGRASS_errors wiki to the course webpage so I hope that will help.
I have a visiting student who had to go through the steps listed there to get GRASS7 working, but it seemed to work fine after that.
We also have it running on several machines in the lab, but I suggest to wait few days to see whether
any serious problems are reported by students (in addition to the WinGRASS installer issue which we cannot do anything
about as far as I understand it).
Helena
Helena Mitasova
Professor at the Department of Marine,
Earth, and Atmospheric Sciences
and Center for Geospatial Analytics
North Carolina State University
Raleigh, NC 27695-8208
hmitaso@ncsu.edu
http://geospatial.ncsu.edu/osgeorel/
"All electronic mail messages in connection with State business which are sent to or received by this account are subject to the NC Public Records Law and may be disclosed to third parties.”
On Aug 22, 2014, at 8:53 AM, Martin Landa wrote:
grass-dev mailing list
grass-dev@lists.osgeo.org
Hi Helena,
2014-08-23 5:48 GMT+02:00 Helena Mitasova <hmitaso@ncsu.edu>:
please note that it's not RC but beta!
Checking "Important Microsoft runtime libraries" in the installer
should solve this problem [1].
Martin
[1] http://grasswiki.osgeo.org/wiki/WinGRASS_errors#The_GRASS_GIS_.28winGRASS.29_exits_immediately_after_I_start_it.21
On Sat, Aug 23, 2014 at 3:35 AM, Martin Landa <landa.martin@gmail.com>
I think this issue is discussed also somewhere else since I remember
writing this somewhere already. Anyway, at least for the record, checking
the check box does not help. Getting through the 2 other suggestion on wiki
does not help either. But doing the steps from the installer manually works
(the third suggestion). This was the case on two (or more) computers
already.
Martin
[1]
wenzeslaus wrote
On Sat, Aug 23, 2014 at 3:35 AM, Martin Landa &lt;
landa.martin@
&gt;
wiki
works
already.mention Martin
[1]
grass-dev@.osgeo
are you installing winGRASS standalone with admin rights (e.g. right click
run as admin)?
can you test it with and without "run as admin" on these win machines?
can you also test at which manually step mentioned in the wiki winGRASS is
working/not working.
the OSGeo4W-package is unfortunately a moving window...
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/G7-blockers-call-tp5157820p5159968.html
Sent from the Grass - Dev mailing list archive at Nabble.com.
On Wed, Sep 3, 2014 at 6:32 PM, Helmut Kudrnovsky <hellik@web.de> wrote:
> landa.martin@
> &gt;
> wiki
> works
>> [1]
> grass-dev@.osgeo
run as admin)?
I remember trying both options without success.
Anna
best regards
Helmut
not sure, but I suspect some permission rights issue to execute/install the
downloaded runtimes by the winGRASS-standalone installer.
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/G7-blockers-call-tp5157820p5160408.html
<mailto:landa.martin@gmail.com>> wrote:
    > So far I had two students reporting the problem with MSVCR.71.dll
    > WinGRASS_errors wiki to the course webpage so I hope that will help.
checking the check box does not help. Getting through the 2 other
suggestion on wiki does not help either. But doing the steps from the
installer manually works (the third suggestion). This was the case on
two (or more) computers already.
I can confirm this behavior for WinGRASS-7.0.0svn-r61783-1071.
Installing with admin priviliges and checking the box for the MS runtime
environments didn't help but copying the DLLs manually to extrabin did
the trick (as suggested in [1]).
This is a "new" behavior for me - I haven't had this problem with
winGRASS before.
Johannes
    Martin
    [1]
which windows version (7, 8)? any antivirus software?
the winGRASS standalone installer should copy the DLLs to extrabin, see
http://trac.osgeo.org/grass/browser/grass/branches/releasebranch_7_0/mswindows/GRASS-Installer.nsi.tmpl#L943
943 CopyFiles "$TEMP\$ORIGINAL_UNTAR_FOLDER\bin\*.dll"
"$INSTDIR\extrabin"
more informations and investigations are needed ...
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/G7-blockers-call-tp5157820p5160427.html
I saw the problem with both versions. I can't check the antivirus now but
that might be causing it.
the dlls are not there although the installation seems to finish correctly
Anna
"$INSTDIR\extrabin"
best regards
Helmut
<mailto:hellik@web.de>> wrote:
    >>But doing the steps from the
    >> installer manually works (the third suggestion). This was the case on
    >> two (or more) computers already.
    >I can confirm this behavior for WinGRASS-7.0.0svn-r61783-1071.
    >Installing with admin priviliges and checking the box for the MS runtime
    >environments didn't help but copying the DLLs manually to extrabin did
    >the trick (as suggested in [1]).
but that might be causing it.
Cannot check for Windows 8, just for 7 64bit. I'm using Microsoft
Security Essentials but it makes no difference whether it's enabled or
not. No luck even with forced administrative privileges during setup
and/or runtime. Also just checked with the newest build
(WinGRASS-7.0.0svn-r61811-1073).
I've however multiple copies of msvcr71.dll installed on my system with
the one in C:\Windows\Microsoft.NET\Framework\v1.1.4322\msvcr71.dll
being most relevant I assume.
Copying them manually in extrabin still does the trick.
Johannes
Anna
    "$INSTDIR\extrabin"
    best regards
    Helmut
    grass-dev@lists.osgeo.org <mailto:grass-dev@lists.osgeo.org>
Johannes Brauner wrote
On Fri, Sep 5, 2014 at 4:17 PM, Helmut Kudrnovsky &lt;
hellik@
&gt; &lt;mailto:
hellik@
on
runtime
did
Johannes
thanks for reporting.
tested here with WinGRASS-7.0.0svn-r61816-1074-Setup.exe, I can confirm that
the runtime DLLs aren't copied to the extrabin folder.
if the download of the MS runtimes in the winGRASS standalone installer is
activated, the download is correctly untared and unzipped by [1] in
C:\xxxx\normal\AppData\Local\Temp\install_msruntime
then the runtime DLLs should be copied to the extrabin folder by [2]:
CopyFiles "$TEMP\$ORIGINAL_UNTAR_FOLDER\bin\*.dll" "$INSTDIR\extrabin"
but they aren't.
from the nsis documentation (http://nsis.sourceforge.net/Docs/Chapter4.html)
"4.9.3.2 CopyFiles
[/SILENT] [/FILESONLY] filespec_on_destsys destination_path
[size_of_files_in_kb]
Copies files from the source to the destination on the installing system.
Useful with $EXEDIR if you want to copy from installation media, or to copy
from one place to another on the system. You might see a Windows status
window of the copy operation if the operation takes a lot of time (to
disable this, use /SILENT). The last parameter can be used to specify the
size of the files that will be copied (in kilobytes), so that the installer
can approximate the disk space requirements. On error, or if the user
cancels the copy (only possible when /SILENT was omitted), the error flag is
set. If /FILESONLY is specified, only files are copied.
Fully-qualified path names should always be used with this instruction.
Using relative paths will have unpredictable results.
CreateDirectory $INSTDIR\backup
CopyFiles $INSTDIR\*.dat $INSTDIR\backup"
so I can't see any obvious why file copying doesn't work...
anyone any idea?
[1]
http://trac.osgeo.org/grass/browser/grass/branches/releasebranch_7_0/mswindows/GRASS-Installer.nsi.tmpl#L935
[2]
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/G7-blockers-call-tp5157820p5160573.html
it could be the quoting "$TEMP\$ORIGINAL_UNTAR_FOLDER\bin\*.dll" and using
wildcards for the files that is causing that file copying fails.
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/G7-blockers-call-tp5157820p5160574.html
I think I've found the reason causing some troubles with installing MS
runtimes, see:
http://forums.winamp.com/showthread.php?t=379253
I think I've narrowed down the issue a little bit more:
in the nsis-script [1] there's the section [2] with the optional download of
these gzipped and tared files which, after unzpping and untaring, should be
copied to C:\Program Files\myprogram\subfolder.
this section calls [3] the function [4] which download [5] and unzip/untar
[6] the archive and then copies some files [7].
now for more testing, I've added some copying commands as the first action
of the nsis-installer:
    code: ;test copy files
      CreateDirectory "$INSTALL_DIR\extrabin"
      CopyFiles "C:\wd\checkdllnsis\*.dll" "$INSTALL_DIR\extrabin"
      CopyFiles "C:\wd\checkdllnsis\*.txt" "$INSTALL_DIR\extrabin"
      CopyFiles "C:\wd\checkdllnsis\*.exe" "$INSTALL_DIR\extrabin"
      CopyFiles "C:\wd\checkdllnsis\*.dll" "C:\wd\checkdllnsis\copiedf"
      CopyFiles "C:\wd\checkdllnsis\*.txt" "C:\wd\checkdllnsis\copiedf"
      CopyFiles "C:\wd\checkdllnsis\*.exe" "C:\wd\checkdllnsis\copiedf"
and all of these test files are copied.
as summary, CopyFiles doesn't seem to work, if the command is nested in a
function called in a section; but CopyFiles works, if it is in the main nsis
script and not nested in function.
intended behaviour? bug? ... should this be reported anywhere?
best
Helmut
[1] http://trac.osgeo.org/grass/browser/...aller.nsi.tmpl
[2] http://trac.osgeo.org/grass/browser/....nsi.tmpl#L966
[3] http://trac.osgeo.org/grass/browser/....nsi.tmpl#L979
[4] http://trac.osgeo.org/grass/browser/....nsi.tmpl#L900
[5] http://trac.osgeo.org/grass/browser/....nsi.tmpl#L929
[6] http://trac.osgeo.org/grass/browser/....nsi.tmpl#L935
[7] http://trac.osgeo.org/grass/browser/....nsi.tmpl#L943
the solution will may be to cut download and install of the MS runtimes in
two different actions by the nsis-winGRASS-installer.
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/G7-blockers-call-tp5157820p5161666.html
Hi Anna,
hellik@
Anna
by r61832, r61843, r61911, r61951, r62082 I've tried to attempt to fix
installing and copying MS runtime files.
at least here on my windows box, where installing and copying MS runtimes
files previously failed, the windows standalone installer does now the job.
any chance to test standalone winGRASS7.1
(http://wingrass.fsv.cvut.cz/grass71/) above r62082?
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/G7-blockers-call-tp5157820p5164138.html
hellik@
&gt; &lt;mailto:
hellik@
on
runtime
did
Johannes
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/G7-blockers-call-tp5157820p5164141.html
On Thu, Sep 25, 2014 at 9:30 AM, Helmut Kudrnovsky <hellik@web.de> wrote:
Hi Anna,
> hellik@
runtime
correctly
> Anna
Great, I will try tomorrow. I need to ask someone to try it, on the
computers I have access to, it was working before. Have you identified the
problem or are you still guessing?
Thanks!
best regards
Helmut
hi,
working before.
Are you sure that it has ever worked? Download, unzip and untar the archive
was working, regarding installing and copying I'm not sure ...
Have you identified the problem or are you still guessing?
I've changed the logic order in the script.
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/G7-blockers-call-tp5157820p5164149.html
On Thu, Sep 25, 2014 at 9:59 AM, Helmut Kudrnovsky <hellik@web.de> wrote:
hi,
>working before.
Sure, it was and is still working on certain computers when I check it in
the wizard.
I was wondering if the fontconfig problem I asked earlier could be somehow
related. You haven't probably experienced this problem. I will see after
the testing.
best regards
Helmut
Hi Helmut,
hellik@
&gt; &lt;mailto:
hellik@
on
runtime
did
Johannes
installation (including opting for downloading the MS runtimes) and
start of winGRASS 7.1 (WinGRASS-7.1.svn-r62087-1088-Setup) worked like a
charm.
Thanks for fixing it.
Johannes
Geoinformation Systems - Technische Universität Dresden, Germany
